Electrician apprentice here.
Earth potential is said to be 0 volts.
Let’s say I have a star-configured transformer which supplies me with voltage. Let’s also say that the transformer is perfectly balanced and that the 0 potential center point is grounded to earth.
Imagine then that we have some sort of electrical appliance downstream. That particular appliance is grounded as well, by use of say a copper rod.
So a TT system.
If a ground fault suddenly occurs at my electrical appliance the current will suddenly run in my local grounded copper rod.
However, I am told that this happens only because the circuit is completed by the grounded transformer on the supply side.
But if the earth potential is already zero, why would the current move between the local ground rod and the supply ground rod? Wouldn’t earth merely be what closes the circuit? I mean, after all a closed circuit isn’t necessary in order for a current to exist. Only a potential difference is, right?
