I was trying to implement the watchdog functionality using ASF in an SAMC21 xplained pro and after flashing the code the device started behaving oddly. If I try to run any code it looks like it is not doing anything.
If I try to start debugging it goes directly to Reset_Handler function.
I tried erasing the hole code and also disabling the watchdog timer in the fuses but nothing changes.
What can I do, or what other information should I provide to get help with this issue?
Marcus Müller
  • 94,373
  • 139
  • 252
jagjordi
  • 356
  • 13
The issue was that I was not powering off the uC after changing the configuration of the WDT. Doing that solved the problem
jagjordi
  • 356
  • 13
