I want to know if the polarized capacitor has some advantage that they are used in some circuits?
For example, in a schematic of the BISS001 PIR controller IC, in some places, a polarized capacitor is used and in some places a non-polarized capacitor one.
Can I use a non-polarized capacitor with the same voltage and capacitance instead of these polarizing capacitors?
Reference Docs:
What I've understand from your answers is why the electrolytic capacitors are used, and why these are polarized.
But the designers of this circuit could have used a non-polarized capacitor or even polarized tantalum capacitors. Is it true? As the (Grove - PIR Motion Sensor) module uses polarized tantalum capacitors.
I want to know if the polarized capacitors are being used for circuit protection or is there any other reason (regardless of the type of capacitor.)
Is there a problem if these capacitors are replaced with non-polarized capacitors in these circuits?
Is there a problem if these capacitors are replaced with non-polarized capacitors in this circuits?-- no, there is no problem. But you may find it hard to find non-polarized capacitors of the same specification. Non-polarized capacitors are usually in the nF range and are usually rated for low voltage use (5V or less). If you want anything in the uF or mF and/or rated at tens of volts you will have to make do with polarized capacitors – slebetman Apr 08 '19 at 05:22
