The current in photo diode because of generation rate G and depletion width W is given as qGW (neglecting diffusion currents).
When the light is incident on the diode excess carriers are generated in depletion region in pairs and these are swept to respective P and N regions.
If the above is true, then why we are not taking current because of both holes and electrons i.e. current should be 2qGW.
Marcus Müller
  • 94,373
  • 139
  • 252
We agree that current is constant in a circuit.
Take an arbitrary point in your voltage source - diode circuit. Make a cut. How many charges per second flow through that? That's current.
You'll see that for every recombination, exactly one electron (or one hole) flows. I don't see how that would lead to a factor of 2.
Marcus Müller
  • 94,373
  • 139
  • 252
