I've seen 20*Log10(amplitude) as the proper way to calculate dB, where 0 < amplitude <= 1. (So, to get amplitude when signed integer data types are used to represent amplitudes, you use value/maxvalue for positive values and value/minvalue for negative values.)
I know this formula generates 0 for extreme values and negative numbers for everything else. I also know it's showing a relationship between the sample and an extreme sample value. Is this properly called dBu or dBv or something else? I've seen both, plus just "dB".
I didn't study electrical engineering, so as close as you can get to a layman's explanation of why a particular unit is correct would also be helpful.
