-3
Would you please help me to know this IC."MC1MX31LDVMN5D"
Lundin
  • 20,162
  • 26
  • 76
    Did you try typing mcimx31 in your favourite search engine? – Lundin Jan 07 '19 at 13:38
    @user2630726 https://electronics.stackexchange.com/questions/334128/how-do-i-identify-smd-components-or-how-do-i-identify-any-component/334129#334129 – Voltage Spike Jan 08 '19 at 19:53
That is a Freescale i.MX31 "Applications Processor" based on an Arm11 core which apparently has some hardware image processing support.
You can read all about it on Freescale's website.
To an extent, figuring something like this out depends on having enough sense of what is out there to recognize which letters and numbers in the agglomeration are key, and then doing a search on those. So for example, in this case, knowing that "imx" was a processor family.
An "application processor" tends to be a step up from a microcontroller and differ by relying on external memories and often having an MMU. Architecturally it might not be that different from say a trailing edge tablet SoC, and sometimes can run a full operating system like Linux, but is generally much less powerful (ie, slower) and may often be used with a more compact embedded operating system or RTOS.
Chris Stratton
  • 33,491
  • 44
  • 90
  • Why would Freescale print "CHINA" on the part though? I've never seen that before. Some custom print? The first line is the part, second line the silicon mask, third line manufacturing batch. – Lundin Jan 07 '19 at 13:37
  • Because it was (mostly) manufactured in China. – Lior Bilia Jan 07 '19 at 15:07
