I am building a system where I am controlling 2 LED strips using an Arduino Uno, time chip and relay. I have managed to get the lights to turn on and off on 2 separate days at different times. Now I want to add a switch to override the program, turning the lights on, when they are not programmed to. I would also like to add an LED to show when the switch is active.
Here is my code.
#include <DS3231.h>
int Relay = 4;
String today ;
DS3231  rtc(SDA, SCL);
Time t;
void setup() {
  Serial.begin(9600);
  rtc.begin();
  pinMode(Relay, OUTPUT);
  digitalWrite(Relay, LOW);
  delay (2000);
void loop() {
  today = rtc.getDOWStr();
  if (today == "Thursday") {
    if ( 15 > t.hour && t.hour < 22) {
      digitalWrite (Relay, HIGH);
    else{
      digitalWrite (Relay, LOW);
  if (today == "Friday") {
    if ( 16 > t.hour && t.hour < 23) {
     else{
How am I best proceeding?
Add a boolean that indicates whether the leds are on because of the time. replace digitalWrite with setting that boolean.
Then you add an if:
bool switchOn = digitalRead(switch) == HIGH; //when using pulldown configuration
bool timedOn =false;
      timedOn = true;
    } else {
      timedOn = false;
} else if (today == "Friday") {
      timedOn = true;
    } else {
      timedOn = false;
} else {
    timedOn = false;
if(switchOn || timedOn){
} else {
if(switchOn){
    digitalWrite (indicator, HIGH);
} else {
    digitalWrite (indicator, LOW);
ratchet freak
  • 2,823
  • 15
To literally override the Arduino program, you just have to connect a toggle switch across the contacts of the relay that controls the LED strips.
To sense that the switch is closed, you could use a two-pole switch, with the second pole connected to an Arduino digital input.
Peter Bennett
  • 59,212
  • 49
  • 132
