How can I work out what voltage and amps are required to heat nichrome to:
Temperature: 220 F Length: 100 cm Gauge: 20 (0.85 mm diameter, 1.62 ohms per meter)
I think I need 7 volts and 3 amps.
I have a lab power supply that is 15 volts and 40 amps.
Work it out from the wire on a 1kW heating element in an electric fire. Measure the resistance, and use the mains voltage to get the current flow. That current will make any length of similar diameter nichrome glow red hot.
Or, in round numbers, if you have 110VAC creating 1kW heat that gives you about 10A
