I was reading about SCRs and I'm trying to simulate 2N5060 SCR but having some issues when I plot the currents and voltages:
First by looking at the datasheet, I set the R4 to keep the gate current a bit less than 200uA.
For V2 I set the on time for the 5V gate pulse as 50u and 100us period.
I set a load which does not exceed 0.8A rated.
And here is the current through R1:
and here is the zoomed view:
And here is the plot of the voltage at the gate node:
Why is the load current has so many spikes?(it even gets worse with the shorter pulse ON times)
Is the gate voltage normal? It doesn't go to zero volt even I put a resistor between the gate and the cathode.
Why doesn't this SCR rectify the current? It passes the current both way, see my first plot.
I might be doing something fundamentally wrong but couldn't figure out the source of the issue.
edit:
The gate current:
Edit 2:
I increased the gate current as suggested and it still doesn't work.
And here is the SPICE model:
*SYM=SCR
*SRC=2N5064;2N5064;SCRs;TECCOR; 200V 0.8A
.SUBCKT 2N5064   1 2 3
*    TERMINALS:  A G K
QP  6 4 1  POUT OFF
QN  4 6 5  NOUT OFF
RF  6 4    400K
RR  1 4    267K
RGK 6 5    80
RG  2 6    9.09
RK  3 5    0.112
DF  6 4    ZF
DR  1 4    ZR
DGK 6 5    ZGK
.MODEL ZF   D (IS=3.2E-16 IBV=100U BV=200)
.MODEL ZR   D (IS=3.2E-16 IBV=100U BV=200)
.MODEL ZGK  D (IS=3.2E-16 IBV=100U BV=5)
.MODEL POUT PNP (IS=320F BF=1 CJE=402P TF=102U)
.MODEL NOUT NPN (IS=320F BF=100 RC=0.45 CJE=2.01N CJC=402P TF=3.74U)
.ENDS
user1245
  • 4,125
  • 38
  • 95
  • 2N5060? That's odd. SCRs are usually 3N or 4N. – Hearth Nov 04 '18 at 17:49
  • It says Sensitive Gate Silicon Controlled Rectifiers. Maybe I chose the wrong device to play with.. – user1245 Nov 04 '18 at 17:50
  • Anyway, it looks to me like your SCR is never actually turning on. The leakage current spec is that it can pass up to 50μA DC when turned off (though this data is at elevated temperatures, but I have no idea what temperature your SPICE model assumes), so it's well within spec. – Hearth Nov 04 '18 at 17:53
  • What is the actual gate current? I think you're not actually giving it the current it needs to turn on. – Hearth Nov 04 '18 at 17:56
  • I will add the gate current plot now – user1245 Nov 04 '18 at 17:57
  • Here is the gate current: https://i.stack.imgur.com/h5CCs.png – user1245 Nov 04 '18 at 17:58
    Well, whatever's happening, your thyristor isn't turning on. You're using it in a strange mode of operation, and your gate current is marginal, so I'm not sure exactly what the problem is but I'd suggest increasing V1 and decreasing R4, see if that gets it to turn on. – Hearth Nov 04 '18 at 18:04
  • @Felthry Nah, we used a zillion 2N5064 (same thing but higher voltage) back in the day. SCR, all the way. Motorola IIRC. – Spehro Pefhany Nov 04 '18 at 18:43
  • @SpehroPefhany Odd naming convention (pretty sure the JEDEC standard is that 2N means two junctions, or at least it used to be), but it's definitely a thyristor, yeah. – Hearth Nov 04 '18 at 18:46
  • @Felthry 2N6028 was a 4-layer PUT, used in the same product. They kind of went nuts with those names. At least the TO-92 triacs had MACxxx names, IIRC. – Spehro Pefhany Nov 04 '18 at 18:48
Below the trigger current, the SCR will act a bit like a transistor, so the gate current will be reflected in the anode current.
When the trigger current is reached, 200uA minimum in this case, the positive feedback takes over (given a sufficiently low load resistance) and the SCR latches on until the current drops below the holding current (stated as 5mA maximum for this part, but typically closer to the trigger current).
Edit: I don't have a working 2N5060 model,and I'm not going to import one, but here is the behavior with a 2N6564 which is similar. I've reduced the gate resistor and the load resistor. You can see the jaggies in the anode current near the zero crossings due to not reaching (or maintaining, on the falling edge) the minimum holding current.
The lack of triggering at low current may be a timing thing- the 200uA is okay for DC but not for 50usec pulses, or it could be a problem with the model, you can poke it and find that out.
Spehro Pefhany
  • 397,265
  • 22
  • 337
  • 893
  • Please see my edit 2. I increased the gate current to 600uA still doesn't work. I also added the SPICE code for that rectifier. – user1245 Nov 04 '18 at 19:25
    @user164567 You need to increase it even more, Spehro uses a value of 500, not 8k. In fact, try it with 650 and see the results. I think it would be a minor revelation. Don't forget that SPICE is SPICE, and models can only get as good as the creator made them, they almost never are a perfect match. Also, usng a value of 0 for the rise/fall edge (in LTspice) doesn't mean instant rise/fall, it's physically impossible, so the default values are used, which are 10% of Ton. – a concerned citizen Nov 05 '18 at 06:23
You have wrongly interpreted the datasheet.
\$I_{GT}\$ Gate Trigger Current is the minimum current needed to trigger the SCR, not the max current it can handle.
\$I_{GM}\$ is the maximum gate current.
Hence your gate current need to larger than \$0.2\textrm{m}A\$
Also, add SCR spice mode.
I do not know why but this SCR start to trigger when Igt ≈ 10mA
Do you have in your LTspice the component named Scr_params?
If so use it instead and set these parameters enter image description here
.subckt 2N5064
    Scr params:
    + Vdrm=200v  Vrrm=200v    Ih=5ma       Vtm=1.7v     Itm=1.2
    + dVdt=30e6  Igt=0.2ma    Vgt=.8v      Ton=3.2u     Toff=30u
    + Idrm=10u
G36
  • 14,576
  • 20
  • 36
