My country's power supply is AC 220 V. My equipment is rated 220 V 5 mA and linked to a power socket rated 250 V 15 mA.
Will my equipment be fine?
Mains equipment and power sockets are usually rated in amps (A) rather than milliamps (mA) - so I would assume that:
Regardless of this, the socket will only supply the current that is required. So your equipment only requires a third of the current that the socket is able to supply - so there is no problem in that respect.
If it situation was reversed, and your equipment needed 15 A and the socket could only supply 5 A, then there would be a problem, and the equipment would not be able to function correctly, or overload the socket.
When matching devices and power supplies Just remember: Voltages need to be matched, whereas current drain needs to be less than the supply.
In other words:
