Is it possible to create a circuit with an op amp (single supply) that have a nonlinear gain (below 1) slope and a start offset?
See image Green = input Red = output
Honken
  • Yes, it is possible. If you want an overall non-linear response then you add non-linear components to the circuit. You need to supply more details if you expect a more detailed answer. In particular, how precisely do you want to control the point where the gain changes? – Elliot Alderson Aug 01 '18 at 22:09
  • Thanks for the reply, I need to be able to adjust the gain breakpoint by 0.1V. The breakpoint should be at 1.5V and the input is between 0-5V DC. The output will end at 4V when input is at its maximum (5V). – Honken Aug 01 '18 at 23:19
  • What do you mean by "able to adjust the gain breakpoint"? Do you mean by redesigning the circuit and selecting different components or by twiddling a knob? – Elliot Alderson Aug 01 '18 at 23:36
  • Redesigning when doing simulations... – Honken Aug 01 '18 at 23:45
Something like this should work for you. You can adjust the breakpoint by adjusting R2/R3 ratio (currently set at 1.5V). That will also affect the voltage at the endpoint so you'll need to change the R1/R4 ratio if you want to preserve the 4.0V out for 5.0V in.
schematic
Spehro Pefhany
  • 397,265
  • 22
  • 337
  • 893
A precision clamp circuit will do what you want. Consider this: -
U1 and U2 act as clamps. They clamp the signal at a positive level of V1 and a negative level of V2 (as shown in the little picture under the "clamped output").
If R1 becomes a pot then you basically have a new signal that is somewhere between fully clamped and not clamped at all. If the input doesn't go negative then you don't need the U2/V2 circuit.
Andy aka
  • 456,226
  • 28
  • 367
  • 807
You start with a non-inverting differential amplifier with 0V reference then increase the gain when Vout =Vth of transfer function and then increase the gain to linearize the input. Since the non-inverting gain is always 1+ Rf/Rin, you have two choices; { if Vout > x , increase Rf or if Vin >y decrease Rin.
For Rin, Depending on the voltage error tolerance of linearity you have options to use a precision switched resistance or a std Zener or better, a precision Zener IC with a series R, all in parallel with the fixed Rin to increase the gain.
When the threshold of the Zener is relatively low resistance , Zzt compared to the fixed Rin, the knee is as sharp as you need it to match the input response.
Tony Stewart EE75
  • 54
  • 185
