For example, I have a motor that needs a surge of 2.5A for a short amount of time from a 6V power supply.
Will any 6V battery able to supply that current? Even if let's say it has only a 500mAH. How does AMP rating matter when talking about this?
AznBoyStride
  • 149
You might want to use rechargeable NiMH batteries instead of alkaline cells.
This Energizer AA NiMH cell is specified for 4.6A continuous discharge current, for example - way more than typical alkaline cells can provide. It'll probably provide even more current for a few seconds. Plus, you can recharge it!
Five of those in series and off you go.
Jonathan S.
  • 18,288
  • 34
  • 56
For a common 9 volt battery - almost certainly not
4 AA alkaline cells (6 volts) - possibly
4 C alkaline cells (6 volts) - much more likely (although I've seen some C cells that have the same specs as AA cells)
Peter Bennett
  • 59,212
  • 49
  • 132
