I want to shorten the width of a single pulse to 50ms or 100ms width. For example, a circuit generates a positive pulse of duration 1 sec and I need to reduce its width to 50ms, synchronized to the rising edge of the input pulse. How can I do this? Thanks
Asked
Active
Viewed 1,162 times
Is this for 5V logic? – Tony Stewart EE75 Jun 24 '18 at 15:08
What you want is called a monostable multivibrator, or one-shot for short. You set it up to trigger on the leading edge of your signal. It will the produce a pulse of fixed duration.
You set the duration with timing components, like a resistor and capacitor. There are 74xxx series chips that are intended for exactly this purpose. Look thru a selector guide.
Olin Lathrop
- 313,258
- 36
- 434
- 925
Thank you, can you suggest a schematic. I can calculate the rc timing. All I want is the the circuit to work when the output pulse width be shorter than the input. – JTrah Jun 25 '18 at 09:06
