At the time of my plc system inspection i found that my smps input is correctly connected with 230v ac supply but when i check the output + and - voltage with respect to ground i found in both condition the voltage was zero but when i measure in between + and - it was +24 .
And when its output connected to my plc system, it is found that the output voltge + with respect to gound is zero and - with respect to ground is -24 volt, how is this possible amd my system is healthy.
Can you explain it how is this possible??????
