How to close a circuit using a 5V power signal?
Essentially the goal is turn on an AV receiver, using the internal power ON/OFF switch, to activate using a 5V control signal. The receiver now uses a mechanical switch to bridge a signal wire to ground to somehow activate the system power relay. So internal ON/OFF signal wire to gnd starts system. I tested a 220 ohm resistor across switch, which did not work. Only shorting switch pins turns on the system, where one pin is gnd.
When I tested a 2N3904 transistor, 5V & 20k ohm on B, CE resistance still was ~300 ohm measured on a multimeter. Which is not grounded.
If you can help I will truly be eternally grateful. Thanks, Mike
See my answer below and select it as best if it works (I am sure it will).
– paki eng May 27 '18 at 10:57
