Is it okay to replace my worn li-polymer 3.8v and 2200maH battery with a li-ion battery with 3.7v and same 2200maH capacity?Will the 0.1v be of any harm to the delicate electronics of the phone?
Asked
Active
Viewed 912 times
how are you planning to charge the battery? – jsotola May 14 '18 at 22:04
Don't. Charging and thresholds are different for those chemistries. – Andrés May 14 '18 at 22:25
Your battery might explode – Voltage Spike May 14 '18 at 22:36
0.1 V no problem and 3.6V float charger is ok too if all you want is a cheap non Mobile solution – Tony Stewart EE75 May 14 '18 at 23:10
Repair questions are off-topic here. And even if they were not, this is unanswerable because the voltages you quote or the nominal voltages, not the charge cutoff voltages. Such a lack of information about how the actual design works is why repair questions are considered off topic. – Chris Stratton Aug 12 '19 at 14:08
Charging voltage for the newer Li-Po cells is usually 4.35 V. When you use an older Li-Ion cells in modern phone, the battery standard charge level of 4.20V will be exceeded substanially. It might be OK to charge a 4.2V battery with 4.35 V levels, but battery cycle life will be decreased about 3-4-fold, as this example shows.
But before worry about all this, check the actual charging voltage on your phone, maybe it is just 4.2 V standard.
Ale..chenski
- 40,470
- 3
- 39
- 109
With all the questions regarding battery swapping Do you know if there is a reference question that could be a generic answer to most common questions (safety, charging caracteristics, etc...)? – Simon Marcoux May 15 '18 at 01:18
4.35 V is LiFePO₄ (aka lithium iron phosphate). LiPo is lithium-polymer, which is just a way of manufacturing the cell; there's nothing special about its chemistry. It's 4.2 V just like standard non-polymer li-ions. – Hearth Dec 14 '19 at 21:06
