I was buildiing an amplifier circuit for +ve voltages only. When I used a 9V battery to supply V+ and V- (+ to V+, - to V-), I get a constant 8V at the output of the opamp. The output is not changing with respect to input. The circuit worked fine when I used a +/-12V dual power supply. However the way I understand it, using a single supply is okay as long as I'm not dealing with negative input voltages.
Asked
Active
Viewed 3,345 times
Choose to have both inputs near V+/2 and expect DC to Vout=V+/2 , you may have to AC couple unless you can define here – Tony Stewart EE75 Mar 30 '18 at 03:18
1What op amp are you using? – C_Elegans Mar 30 '18 at 03:21
You mean +/-12V. I tried dividing a 9V battery to make a dual supply, but when I connect it to the opamp, I get different voltages at + and - terminals. – sixter Mar 30 '18 at 03:21
@C_Elegans LM741 – sixter Mar 30 '18 at 03:22
Can you simply use two 9V batteries to provide +9 and -9 volts to the opamp power pins? – Michael Karas Mar 30 '18 at 04:09
Can you show us the schematic for the amplifier that worked with $\pm:12:\text{V}$? It would go a long way in helping you, I think. There are different approaches to getting something working on a single $9:\text{V}$ supply (with $1-2:\Omega$ series impedance.) – jonk Mar 30 '18 at 04:45
You could consider a discrete rail splitter. It's not designed for an 9 V battery. But at least you can see the complexity involved. You really need to specify the current compliance you need. – jonk Mar 30 '18 at 06:10
3Reasons not to use a 741 – Andy aka Mar 30 '18 at 07:35
According to page 4 of the LM741 datasheet, the minimum supply voltage is +/- 10V, so powering it with +/-9V isn't guaranteed to work. The LM741 is a very old design, and its characteristics are not as good as modern op amps (that being said, it works fine, but it's not what I'd pick for a new design). I'd recommend getting a more modern op amp, you probably want one with rail to rail inputs and outputs as well as a lower minimum supply voltage. I've narrowed down the listing here, you still will want to make sure whatever you pick can use the supply you're planning to use.
C_Elegans
- 2,901
- 15
- 27
I see. Thanks for the answer. I do happen to have an NE5534 op amp with me. Can I use it to overcome these problems? – sixter Mar 30 '18 at 03:46
Read the datasheet. It will tell you the minimum and maximum supply voltage – C_Elegans Mar 30 '18 at 03:57
@C_Elegans - Also note that he's not using two batteries - just one. So no +/- 9. – WhatRoughBeast Mar 30 '18 at 08:27
