This module that I got from ebay
has a cut-off voltage of 2.5V which is way too low. At that point your Lipo is probably dead. Anyone succeeded in increasing this to higher voltage? I would like to have it at 3.3V .
On many of these typical lipo chargers the small 6 pin chip is the over/under protection component. If that part is a DW01 (as it looks to be), then all of the parameters are preset internally.
Even if you added a resistive divider to the sense pin you would be altering both the overcharge and undercharge values.
Here is the data sheet for the DW01 chip: http://www.ic-fortune.com/upload/Download/DW01x-DS-17_EN_53550.pdf
So if this does not match your requirements you need to buy a new board and/or try returning the original one.
Problem is that I cannot find any board on ebay that has 3.3 as undervoltage. All I find have 2.5 which is strange since LiFePo are not so common and are pricy and 18650 is the most widespread. So I would expect more modules that would suite it.
– bortek Mar 01 '18 at 13:57
https://forum.banggood.com/forum-topic-154248.html
– bortek Feb 28 '18 at 14:48
