How is it possible to safely disconnect/turn off an inductor that has current through it without causing a huge backward voltage? Even dropping from a circuit with low current, it the current will still be going from finite to 0, in a very small space of time (how would you calculate this time?), causing a big voltage spike. How can inductors possibly be safe if disconnecting them is so dangerous?
Asked
Active
Viewed 267 times
1Disconnecting from where? – Eugene Sh. Feb 26 '18 at 21:51
1Without details, we cannot give you an answer. – Feb 26 '18 at 22:15
1You don't normally disconnect components from a circuit while it's operating, so their safety in doing this is irrelevant. – Finbarr Feb 26 '18 at 22:34
@Finbarr Are you familiar with switches or buttons? Disconnecting components from active circuits is routine. I would wonder how you stop anything from operating otherwise, let alone changing its state. – Samuel Feb 27 '18 at 22:08
You use a flyback diode.
Knowing the name, you can search regarding your specific application, such as for a relay.
Samuel
- 11,891
- 32
- 51
