I've recently been given a 24W 230VAC 2 pole shaded pole motor(Mellor Electric AC1004) to make a fan out of. This fan needs to have a variable output speed depending on the temperature of the room. I am quite new to motors and was wondering how to make the motor speed variable. I have done some research and seen that by just varying the voltage the speed can be reduced, however I believe this is not the best way to go about this. I've also seen people use Triac based dimmers in order to accomplish the same thing as well as VFD's but they are quite expensive(VFD's) and i don't think they are suitable to this. I would like some input as to what method would be best. Thanks.
You first have to understand the speed of any drive is the result of the torque of the motor and the countertorque of the mechanism you want to drive. This is called the operating point. Changing the speed means moving the operating point.
These are (roughly) the hilly torque/speed characteristic of an asynchronous machine (as a shaded pole motor is) and a pump/fan.
If you placed an obstacle in the air channel of the fan, you made its characteristic steeper, so the speed of the whole drive would reduce about a tiny bit. I give this example to show you how speed control works.
If you reduced the voltage, the motor characteristic shrinks along the torque axis. Again, the speed of the whole drive would reduce only a tiny bit. If you reduced the voltage too much, the motor hadn't got enough torque to drive the fan. It never reaches the part of its characteristic right of the hill.
If you reduced the frequency, the motor characteristic shrinks along the speed axis. That's a great way to control the speed of the drive, but to avoid magnetic saturation of the iron parts, it had to be accompanied by a proportional voltage reduction for a given motor.
If you placed a resistor in row with the rotor windings of the motor, you made it's characteristic tilt left. Now voltage reduction will reduce the speed of the drive much more. That's what's done in motors designed for that kind of control, the ones usually used for fans, vacuum cleaners and so on. This is the so called squirrel-cage rotor. If your motor has such a rotor, reducing the voltage is the best way to control it.
- 14,276
- 1
- 21
- 35
Good theory, but how do plan to put resistors in the squirrel cage rotor? 99% of the time it's cast aluminium or copper, i.e. a monolith. – rustyx Jul 29 '23 at 09:50
The squirrel cage is the resistor. The whole point of it is increasing the resistance of the rotor. So the torque/speed-characteristic of the motor is on the right of the hill not as steep as shown in the graphic but about 1:1. That way, lowering the voltage will lower the speed of the drive a lot more than with an almost vertical characteristic. – Janka Jul 29 '23 at 12:41
You can even go further and use double rungs in the squirrel cage, with the outer rung having a much smaller aluminium cross section than the inner one. Because the slip determines the strength of the skin effect in the rotor, such a rotor has a high resistance at low speeds and a low resistance at high speeds which means its characteristic becomes a single curve without the torque hill nor turning points. – Janka Jul 29 '23 at 12:47
Voltage-only control of a Shaded Pole (SP) motor is an acceptable method and is the most common. It doesn't work on other types of AC motors, but because of some of the inherent design aspects of what make a SP motor work in the first place, the torque / speed relationship is more or less linear, or can be made to appear so. The point is, you CAN use a single phase output VFD if you have money to burn, but a "dimmer switch" works fine and will not hurt that motor.
- 3,645
- 12
- 12
Triac-type dimmer switches are commonly used to "throttle" ceiling fans. They have the shaded pole motors, so if you have a shaded pole motor device, go right ahead to use a normal dimmer as a throttle for that device. Also, series-wound "universal" motors can be throttled the same way. So can many (though not all) brushless DC motors can be throttled. Note that brushlesss DC motors have electronics to do the commutation for otherwise a 3 phase synchronous motor.
I've tried using an AC dimmer to control a shaded pole motor's speed. Didn't work for both digital dimmer and analog/potentiometer dimmer. Not sure where people are discovering that voltage and not frequency controls the speed of synchronous motors. – Popeye Apr 26 '23 at 14:37
