Could anyone please tell me how LO rejection is defined in a mixer? I've heard Image Rejection but not LO rejection.
Please help!
Thanks.
Please help!
Thanks.
In an ideal balanced mixer, the LO is fed via balun in antiphase to a matched set of diodes, and so cancels completely at the other ports.
In practice, the balance of the balun and the didoes is not perfect, and some LO leakage emerges. This is more problematic at the RF port which has a similar frequency range to the LO, than at the IF where it's easy to filter.
LO rejection is defined as the ratio of leakage out to LO in. For a mixer without active controlled LO cancellation, -40dB might be an aspiration, -30dB is commonly seen, sometimes you have to put up with -20dB.
