I have a 12 V power supply that connects into a custom made power board that then has three 5 V outputs. There are three things connected to it's working all the time.
How does that work, because 3 x 5 is 15 not 12?
Marcus Müller
  • 94,373
  • 139
  • 252
  • Hey! Welcome here! You don't have to ask for us being nice! Please, instead, use a title that actually describes your question at all (instead of "very basic question, please be nice", which says nothing about the question at all). So, I'll go ahead and improve your question a bit by removing all that is only distracting from the question and using a proper title. – Marcus Müller Oct 14 '17 at 14:57
  • AmpsVolts = Watts Its a little unclear why your are trying to mulitply 35. If each device was drawing and amp, you'd get 15W – Voltage Spike Oct 17 '17 at 04:54
That is a power supply, so its job is to generate the voltages you need.
First observation is: A voltage is a voltage, and there's no inherent reason you should be thinking they need to add up.
For example, the three 5V outputs could simply be independent – meaning that the power supply actually looks more like:
schematic
As you can see, nothing here adds up voltages – so there's not even any question of how the output voltages' sum can be larger than the input voltage.
It's also quite likely that the negative supply sides are internally connected, so that out1- to out3- are actually internally connected. That still doesn't introduce any reason to think about the sum of these voltages – the voltage sources are in parallel, not series.
As a side note, even if the power supply actually generated 15 V from the 12 V input, that's not a surprise – there's step up converters for both DC to DC as well as from AC to AC (a typical example of the latter would be a simple transformer with more windings on the output side than on the input side).
It might be of interest to you to learn a bit about basic linear networks, and when to add voltages or currents and when not to.
Marcus Müller
  • 94,373
  • 139
  • 252
schematic
Figure 1. 12 V input. 3 x 5 V output.
The circuit of Figure 1 shows the likely internal arrangement.
  • There is one internal 5 V regulator.
  • The three outputs are in parallel - not in series.
  • Any number of outputs can be wired in parallel from this device provided they don't exceed the maximum power capability of the regulator.
  • Note that all the devices will share a common negative. This is often important when hooking up various circuits such as audio devices.
Transistor
  • 175,532
  • 13
  • 190
  • 404
Your view that voltages have to add up is flawed. A similar add-up flaw applies to currents. But when you consider power, the add-up rule does apply. That is, real power entering is always equal to or larger than real power delivered. Any missing power (where power out is less than power in) is dissipated as heat.
For your example, you'd measure power delivered to each of those three devices (current1 x 5V + current2 x 5V + current3 x 5V). Then compare with power into your power board (current in x 12V).
glen_geek
  • 25,809
  • 23
  • 53
