I am searching some thread about but i don't find it.
3 days ago. My ATX power supply has burn by overheat. Thermaltake TR2 600W.
it has a OTP and even with that it hasn't turned off. Blown by overheat. But aside that. What i am intrigued is, WHY the heck only the +5VSB is giving me output. The other +5V and 12V, -12V, and 3.3V has fall out.
Maybe the secondary side has burned. or the +5VSB is independent from the primary side.
Maybe transistor. Transformer.What is more common?
Anyone know about it?
I can't fide any circuit similar what i have. and isn't available this schematic.
Thanks.
Thanks for people that has actually tried to help. but i don't understand why my question has been negative.
Some people, i guess, have the same question and didn't have the courage of asking the question or don't know how to ask the question. I had researched much before asking this. This atx by me has been like dead. Because it isn't trusted to be used on PC. But i am using an atx that i recovered by changing the capacitor before 500w.
but if i recover this thermaltake, it can be used as a power supply bench. Tried Reverse engineer it, but it's a complex circuit. so only could do main component.
the dead atx has not any signal of burned component, so i will verify any point on board. Transistor, Transformer. Voltage on each path.
So just assumed that i want the answer resolved. Or it can't be useful to anyone. or if it is Unclear, Just ask again what i meant by that.
Again, thanks for the guide.
