33
A question so simple I've never thought about it before. Usually I get my PCBs made in standard green, but have been offered a blue for my next revision of an existing (green) board at no extra cost.
What colors are available as standard, and why should you choose one over another. Is there a "best" color?
Would any of this affect color blind tech people who work on the board?
Dirk Bruere
  • 13,723
  • 54
  • 115
    What colors are available as standard: Whatever the manufacturer offers. Is there a "best" color: Whatever suits your needs, and/or tastes, and/or wallet. – Dampmaskin Aug 30 '17 at 09:15
  • 32
    I like my soldermask in camouflage. It adds a bit cost but makes it harder for the bad guys to find my stuff. – PlasmaHH Aug 30 '17 at 09:21
    Everyone offers green. Most manufacturers will offer other colours but some will charge more for them, it depends a lot on how their process and production line have been set up. I've also heard that some colours can have different minimum line thicknesses but again that is probably manufacturer specific. Some manufacturers also offer different colour silk screen. – Andrew Aug 30 '17 at 09:25
  • 16
    I normally use green, but reserve red for prototype boards so they can be put through the factory without anyone mistaking them for production boards. – Steve G Aug 30 '17 at 10:35
  • 47
    If you're selling to audiophools, then each color has a different sound. – Olin Lathrop Aug 30 '17 at 11:10
    Don't trust black from any old supplier for critical stuff, though - dying plastics of any kind black can involve ever so slightly conductive carbon pigments, which could increase leakage currents or lower dielectric strength. – rackandboneman Aug 30 '17 at 12:16
  • I guess like most people I'm so used to green, that only this thread has made me wonder why green was chosen in the first place. Was it the easiest or cheapest to produce, or chosen at random? – Ian Bland Aug 30 '17 at 21:09
    @OlinLathrop - different sound only if you color the edges of the board with a special marking pen .... which I'd be happy to sell to you. – davidbak Aug 30 '17 at 21:13
    Beware some colors make more difficult to inspect the boards (like black). Also, if you do low volume or only prototyping and use an IR reflow oven (not convection) for soldering red and black PCBs you will need to adjust the thermal profile (the first time I tried red PCBs, I burned the first batch). I guess the opposite applies for white PCBs (I have not tried those). I've heard that some colors make the flux residues stand out more than others (in case you don't clean it because you use no-clean flux) but I haven't had that problem. – MV. Aug 30 '17 at 22:25
    Std green is probably best - it is mid visual spectrum (also highest visual sensitivity) so easy on the eyes and good contrast with white label ink. PS: what determines the color of the raw FR4 (glass+resin) substrate? – amI Aug 30 '17 at 23:02
    Since only one answer so far even mentioned color blindness even though it was in the question.... Yes, it can matter for them. The most common kind of color blindness is red/green, so green boards with red hued text/components etc... can give them difficulty, and vice verse, red boards with green text etc.... The former I have never seen, the later I have actually seen a few examples of. – ttbek Aug 31 '17 at 10:21
    When in development, we have used a different color for each major spin. Makes it easy to see at a glance which of several you're dealing with, from "first attempt" up through "released to production", etc. Choose a silk screen color that has good contrast for reading - White on green, black on yellow or white. – MickeyfAgain_BeforeExitOfSO Aug 31 '17 at 11:26
10 Answers10
30
The color comes from the soldermask, so what you're really asking is what colors of soldermask are available. The answer is that you can get just about any color soldermask, but the less common ones may cost more depending on your manufacturer. Different manufacturers offer different standards. One manufacturer may only offer green as standard and you'll need to pay a premium for blue, red, etc.
To answer your main question about what is commonly available, I have seen green, blue, purple, red, black, and white. Those seem to be the most popular. At work we use green boards to indicate leaded assemblies (because in the past, prior to RoHS restrictions, all of our boards were done in green), blue to indicate RoHS-compliance, and red for prototypes. There is no "best color", it is completely up to you. Personally I don't care for black soldermask or white soldermask because it is difficult to see the traces which could be useful for troubleshooting.
DerStrom8
  • 21,314
  • 63
  • 97
    There are some slight differences between the different solder masks for speciality situations (very-high-impedance circuits where nA leakage is significant, characteristic impedances, etc.) However, when you are dealing with those kinds of situations you often omit the solder mask entirely. (or at least in that location) – Joren Vaes Aug 30 '17 at 13:00
  • Is no-color (I mean, transparent) available? – Константин Ван Aug 30 '17 at 16:14
  • I believe so, though I have never seen it in person. I imagine it is a high-price item though. – DerStrom8 Aug 30 '17 at 16:40
  • OSHPark for example, offers purple as standard ;) – Doktor J Aug 30 '17 at 18:48
    @DoktorJ I had them in mind when I wrote this but purple soldermask is usually considered non-standard for most manufacturers. I often wonder why OSHPark chose that for a color. Probably to make their boards stand out ;) – DerStrom8 Aug 30 '17 at 21:38
  • Dyed-through PCB materials seem to be available, though.... – rackandboneman Aug 31 '17 at 03:54
  • Black soldermask is a bad idea for IR reflow ovens. – Simon Richter Aug 31 '17 at 11:48
    FWIW, I chose Yellow when ordering from PCBWay and it was a pretty nasty gold sort of colour. Wish I'd just gone green :) – Matt Lacey Sep 01 '17 at 05:27
As said by others, the color is the result of the solder mask used.
However, it's definitely not true that color is the only difference. For example, Paul Stoffregen of Teensy fame found that a black solder mask had reduced resolution than a green solder mask, and this directly led to lower reliability of black boards.
user7761803
  • 200
  • This is likely PCB manufacturer dependent. I have seen tons of high-density black boards which didn't have more issues compared to e.g. green ones. – Dmitry Grigoryev Aug 31 '17 at 08:49
  • Depends on the material and equipment used. I mentioned in my answer not-green may have worse specifications. The PCB fab will usually tell you about it if it's an issue. If they have black as stock, it's unlikely to be a problem or at least they have clearances you need to use. – Barleyman Aug 31 '17 at 09:55
  • Aren't most Apple PCBs black nowadays? Also lots of flagship phones... I think it's just if some shitty board shop decides to use some budget black soldermask (colored with carbon black) that you'd have problems. – Nick T Aug 31 '17 at 18:59
    In 2008, our Contract Manufacturer advised us that if there were narrow "webs" of solder mask thinner than .003", then the slivers of green solder mask would sometimes disconnect and you would have no solder mask between pads. This minimum width went up to .004" if using blue solder mask. Apparently due to the pigment used. This appears to have been based on their experience with their manufacturer and may be anecdotal. It is possible newer formulations of non-green solder mask resolve this issue. – 1N4007 Sep 01 '17 at 15:51
It's just paint so various colours are available. Okay, it's a special kind of paint so you may get worse specs on not green colour as that's by far most common one. Specs meaning the smallest bridge and clearances.
I've made black and white boards, LED backlights are white for obvious reasons. If you just take regular white colour solder resist, you're liable to end up with pink as the copper will show through. Red is also seen from time to time.
Black PCB with gold (ENIG) treating looks cool but it's harder to see the traces than on green PCB.
Usually I spec on my PCBs "Black if no extra cost"
Barleyman
  • 3,646
  • 14
  • 27
    No, it's not just paint. The main color of a PC board comes from the solder mask. The "just paint" layer is the silkscreen, which is usually white. – Olin Lathrop Aug 30 '17 at 11:12
    @OlinLathrop Oh come on. Silkscreen has nothing to do with PCB colour. Wrt solder resist, I have worked with PCB fab that will actually mix you colour you want if you pay extra. Obviously you don't want that as it costs extra and black resist materials are widely available if not everywhere. – Barleyman Aug 30 '17 at 12:23
    @Barleyman I think OIins point is that solder resist has a very specific function, which is to repel molten solder so that solder retreats to the soldered pads/pins, greatly reducing the chance of solder bridges. Its color is merely a side effect to that main functionality. In that sense, I agree solder resist is not "just paint" :) – marcelm Aug 30 '17 at 13:21
  • Solder resist is what gives normal PCB base material its CTI rating and should not be overlooked. – winny Aug 31 '17 at 21:05
  • @winny Hence again the poor-er specs bit. CTI isn't usually an issue except for example higher CAT ratings for 3-phase devices and the like. If you have CATIII or CATIV you need to do a lot more besides to keep things in spec. I would say in most cases the environment is bigger limiting factor than the solder resist unless you have high-IP rating enclosure or operate in vacuum or something. – Barleyman Sep 01 '17 at 10:18
    @Barleyman For consumer devices, sure. For industrial, it becomes important for compliance and lifetime. – winny Sep 01 '17 at 10:55
An additional "why" ... when possible, I also like to use soldermask colors to denote prototype/test PCBs vs. production. I may have a red or purple (OSHPark) prototype board to test functionality and then move to green for production. I find it helpful when showing photos of a test setup in a work instruction or test report as someone can tell at a glance why flavor of hardware I was using.
I've also used soldermask colors to denote board revisions in a similar manner so that quality inspection or manufacturing doesn't get confused, especially contract manufacturers who may have multiple revisions in the warehouse. Somewhat of a last line of defense just in case.
scld
  • 2,228
  • 15
  • 18
The colour of commercial PCBs comes from the soldermask. Typically the soldermask "ink" is laid down onto the board using a screen-printer, then the ink is cured and finally a photoimaging process is used to make the gaps.
The soldermask "ink" comes in a variety of colours and custom colours can be mixed. The trouble is to change colour requires cleaning the screen printing equipment which wastes a bunch of time and ink. So muost vendors will have a limited list of standard colours which they produce in enough volume to make it worthwhile keeping a screen printer set up for them.
Note that some colours are more transparent than others. White and black soldermasks in particular tend to make it much harder to see the tracks under the soldermask. Depending on your goals you may see that as an advantage or a disadvantage.
Peter Green
  • 22,193
  • 39
  • 82
Each manufacturer will have standard colors- sometimes you can even specify matte finish for some colors. Eg. matte black or green. Most common colors are green, red, blue, yellow, black and white. White is useful for LED boards because it reflects more light, some folks think black with gold is attractive. Yellow tends to be more transparent than the other colors.
You can even ask for a specific color to be produced in some cases - of course there will usually be significant extra costs and/or significant minimum quantities associated with matching a custom color.
There's not a great advantage of one over another in most situations. I have used black for PCBs used in a vacuum to increase emissivity.
Spehro Pefhany
  • 397,265
  • 22
  • 337
  • 893
I just want to add that most manufacturers will indeed charge you money for any other solder mask color than green. The reason for that is that the set-up for different solder mask color is much more difficult and will stop the production line just for your PCBs. But what you can do is to arange the manufecturer to paint your pcb with a legend ink, since usually they have different colors and it's very easy to change the ink tubes.
Of course, if you paint your PCB with the legend ink, you can't print any other ink legend anymore. At least not till the first ink layer is wet. If you are doing high-density PCBs this shoudn't be a problem, because there won't be place for legend anyway. The other option you have is to use solder mask to write the legend in gold or silver, depending on the finish you are using. The manufacturer should be smart enough not to cover anything free from solder mask with legend ink, but you can define it by yourself in the e-data you are sending them.
I'm doing that for one of my PCBs and it's working pretty good so far.
judoka_acl
  • 389
  • 16
    A different solder mask color is not much more difficult, but changing the color using the same machine needs work, causes delays and and produces more waste. If the manufacturer has different machines for different solder mask color, there is no delay, but the additional machines cost money. – Uwe Aug 30 '17 at 14:30
  • Maybe, but I haven't seen in my life a manufacturer that hasn't utilize it's machines and it's keeping one machine for a special solder mask color. Fact is that I don't know a single manufacturer that won't charge you for different solder mask than green. If you know such, please tell me. – judoka_acl Aug 31 '17 at 10:58
I don't recommend using black for a 1st revision because it's hard to see if a part blew out, but I guess that could be a design benefit on a deliverable...
prl
  • 31
Green is obviously the standard, if you take a sample of 1000 different PCB's from different manufacturers, green is clearly the winner. So if you want a standardized board color, you'd better order green.
If your a rebel and like to go against per-defined standards, then go for purple or orange, or if you really need attention, "hot pink". If you just want something different blue will suffice
Yes, you need to implement a system like RHOS to control how much color is on the boards and a require that all products have the correct color of board so that no more color blind people need to suffer.
Voltage Spike
  • 82,181
  • 41
  • 84
  • 220
Colors like green, blue and red are used commonly, as said by others, for lead containing pcb (e.g. solder), RoHs compliant one, and prototype. It's a good choice to distinguish things.
We use black for power dissipation, when we pack a lot of Amps: painting something in black makes a difference. I never noticed effects of lack of insulation, although I confess that I never made an accurate measurement and that the circuits where black soldermask was used are all low voltage (up to 100 V).
andrea
  • 1,599
  • 13
