I'm a complete beginner to electronics so please excuse the simplicity here :)
I have a phone charger that outputs at:
  • 5V - 3A
  • or 9V - 1.6A
  • or 12V - 1.2A
I would like to use another charger while at work, which outputs at:
  • 5V - 1.8A
I don't know what the input for the phone itself is.
  • I assume it's safe to use the second charger because the phone will only take the current that it needs?
  • If the second charger had a voltage higher than the phone's charger, should it be avoided?
  • In general, how would I determine if something is safe to use or not?
  • When do things get to the point of damaging the device, or even worse, starting a fire?
Thanks!
Phil
  • 103
  • 1.8A might be insufficient for the phone which is organically shipped with 3A charger. 2) Using higher voltage is a certain no-no. 3) Too broad. If you don't know how to determine - don't touch it. 4) No general rule. You can start a fire with an AAA battery.
  • – Eugene Sh. Aug 21 '17 at 17:11
  • "I assume it's safe to use the second charger" ... And what if the phone needs full 2.5A of current if it sees the DCP (Chineese) signature? (which is quite unlikely, but as an alternative assumption)? – Ale..chenski Aug 22 '17 at 18:29
