85
With all the technology available today with being able to boost voltage efficiently using SMPS, why do we still use 9V batteries? Is there some secret advantage with them that I am unaware of?
If you look at the size as well, the 9V is just big and bulky and I have designed projects where I can use 2xAA batteries and boost the voltage, which will give me longer battery life than a 9V. And it takes up the same amount of space.
A lot of circuits today also need regulating, and the easiest way to do that with a 9V is a linear regulator (usually to about 5V) and I am aware this is not the case for every design, but that right there is energy wasted, and yet again, boosting the voltage from 1 or 2 AA batteries will probably give your product a better shelf life.
I saw a comparison between a 9V battery and some AA batteries, where someone found the energy available, and ended up with this data: enter image description here NOTE: These results were from Energizer Alkaline batteries. The page can be found HERE.
So with all this data, why are 9V batteries still used in designs? Are there some applications where it would be advantageous to use them? Or is it usually a better idea just to go for the AA or AAA solution?
There have been times where I have considered using a 9V battery for some of my projects but it always seems after doing my calculations, they just don't hold up as well as others, so am I missing something?
For reference, the datasheets for the compared batteries are here: AA 9V
EDIT: I am not intending this to be an 'opinion-based' question, rather, I was intending to ask from a practical point of view, if there were advantages to choosing a 9V over any other solution (such as boosting AA batteries). Just wanted to make that clear!
MCG
  • 11,923
  • 35
  • 71
  • 62
    Boost circuits can be noisy. Plus, they cost more to manufacture than "Batteries not included" labels. – Dampmaskin Aug 08 '17 at 13:55
    "why are 9V batteries still used in the industry?", what industry would this be? Not my industry at least! – pipe Aug 08 '17 at 13:58
  • @Dampmaskin very true. Probably should have added about the way the industry is going, all about space saving and all that stuff, people are always trying to get more with less space. I was finding it difficult to find why people still chose to use 9V as I couldn't find any... electronic reasons – MCG Aug 08 '17 at 13:58
  • @pipe I mean electronics as a whole. Maybe industry was the wrong word.... You still see consumer goods powered by 9V batteries. "in the industry" was just the first phrase that came out of my head! – MCG Aug 08 '17 at 14:00
    power electronics wasn't cheap or small or widely available in the past – user3528438 Aug 08 '17 at 14:01
    I would say it is all about manufacturer legacy design inertia and extremely wide consumer availability. – Michael Karas Aug 08 '17 at 14:07
  • If you use rechargeables then 6 AAs does not equal one PP3. NiMH PP3s tend to be 8.4V (7 cells) and some are even 9.6V, as opposed to 7.2V for 6xAA. – Bob says reinstate Monica Aug 08 '17 at 20:00
    @Bob There's a lot of room for fudging voltages with anything intended to replace alkaline cells because during discharge each will drop from ~1.5V to ~1V when the cell is dead. a fixed 7.2 or 8.4v NiMH replacement is perfectly in spec. 9.6v is pushing the notional spec; OTOH the intrinsic voltage drop in alkaline cells means that any devices using them either need to be able to handle a relatively broad range of voltages directly or have some sort of voltage regulator. – Dan Is Fiddling By Firelight Aug 08 '17 at 20:22
  • +1 to @Dampmaskin. I want to provide an example: Electric guitars with active pickups (e.g. EMG81, Seymour Duncan Blackout) need a 9V battery for an opamp-based amplifier (yeah it's a noninverting amplifier with an output swing of 2Vpp max and an output impedance of 10k) inside the guitar. So, since guitarists/musicians don't want a noisy guitar tone --even if it is distorted heavily, single cell plus a boost circuit would be totally problematic --in terms of efficiency as well. – Rohat Kılıç Aug 10 '17 at 21:32
  • guitar effects "stomp boxes" still take 9v batteries. at least some of them do. it might be that many analog circuits still use discrete parts (like separate transistors, resistors, capacitors) and some of these BJTs might not work so well with a quiescent point lower than 3 or 4 volts. – robert bristow-johnson Aug 12 '17 at 05:56
  • A while ago I did a circuit that has +4V/-4V rails and maybe somewhat under 100µA current needs, I am not quite sure in terms of BOM costs and current requirements if feeding that from a 1.5V battery would give any advantage... – PlasmaHH Aug 16 '17 at 12:24
10 Answers10
103
A 400mAh 9V battery will last a year with a 40µA current draw.
Now consider a smoke detector. It is low power analog circuitry, most likely drawing less than the 40µA figure above. If you wanted to power it from a boost converter and AAs, then you'd need a converter with very low idle current.
But... when there is fire, now you need quite a bit of power, and enough volts, to drive the piezo loudspeaker. These need voltage. 9V is louder than 3V.
So your very low idle current DC-DC converter also needs to output high current if needed.
You also need to be able to measure state of charge accurately on the AAs.
All this will cost more than the difference between 9V and 2AA. And remember, the customer pays for the replacement batteries, not the manufacturer!
bobflux
  • 77,207
  • 91
  • 222
    But surely, the really best design would be to have the detection circuit operate at only 1.5 V without any boosting, and only in case of a fire switch on the high-power boost converter to drive the speaker? – leftaroundabout Aug 08 '17 at 21:46
    A few (10? maybe 20?) years ago I'd have said "because they are there". Early transistor radios were made to run on 9 V because of the germanium transistors they used. So "9 volt" batteries were very very common, easy to find in stores. Not so much any more. My local convenience stores stopped carrying them quite a while ago. – Jamie Hanrahan Aug 08 '17 at 21:56
    Not sure it matters but all the smoke detectors I've purchased in the last 10 years run on AA batteries. – JimmyJames Aug 09 '17 at 19:30
    @JimmyJames: exactly the opposite of my experience. All the smoke detectors I bought in the last 10 years run on 9V batteries. Even the backup for the powered ones was 9V. – Martin Argerami Aug 10 '17 at 13:23
  • Yeah, here in France it's all 9V... – bobflux Aug 10 '17 at 14:41
    @MartinArgerami It used to always be 9V in my experience. It's a fairly recent change. In the US there is a big push to reduce the number of smoke detectors that are left without power. Often in rentals the residents will just pull out the battery when it starts beeping and leave it like that. Since most everyone keeps AAs on hand, it's less of a burden to replace them. The ones I am buying are also more 'advanced' in they they also detect CO and/or are interconnected wirelessly which could be a factor. – JimmyJames Aug 10 '17 at 15:38
    @leftaroundabout The booster is yet another thing to fail, by no means the most complicated part of your design; maybe not something you want in a safety device. In the basic design, the smoke detector is just a battery, the detecting circuit, one relay (probably a transistor-based) and one speaker. And put aside, a voltage check for low batteries. All parts are essential in that you can't be without them. This means the design is as easy as possible. – yo' Aug 11 '17 at 10:36
  • If a smoke detector has a relay, I think it could have two SMPSs, one of which is designed for low quiescent current and another relay-powered one that is designed for high peak current (and thus high quiescent current, which doesn't matter because it's relay powered). – juhist Aug 11 '17 at 13:06
  • Good points. Simple design is more robust. @leftaroundabout Good idea, but better to design the main circuit to draw fewer amps from a higher-voltage battery. Also imagine a WiFi module that wakes up every hour to make a measurement and send the results. 2x CR2032 would easily beat a larger cell with a boost circuit. – kaay Aug 11 '17 at 13:52
    @JimmyJames: People would be less likely to leave detectors without power if there were an easy way to shut off the low-battery chirping for 12 hours or so without disabling the detector. If the detector starts chirping at 2am and the store isn't going to open until 9am, what is someone supposed to do? – supercat Aug 11 '17 at 14:50
  • I like this answer more than the accepted one – Capn Jack Aug 11 '17 at 14:56
    It might be the quality of the detectors I buy :-) but all of them had a simple mechanical latch that made it impossible to put it back into its holder if the battery compartment was empty. – Gábor Aug 11 '17 at 16:36
92
First a AA is not a battery.. it's a cell. A battery is a "battery" of cells, i.e. more than one cell. A 9V battery contains six 1.5V cells. Rip one apart and see.
As for why we still use 9V batteries, it really is a matter of the design. The nice thing about 9V batteries is they give you a fairly wide operating voltage range during their life without being overly high a voltage. They also come in a really nice compact package that has a rather usable clip.
I would in no way recommend using one with a linear regulator to generate 5V though unless the current requirement on that 5V is very small. Better to design your circuitry using componentry that will work at the 9V directly.
It also really depends on the nature of your widget. If you have sensors or transducers that require larger voltages and it's battery operated, it's simpler and usually cheaper to go with a 9V battery.
One also has to consider the ramifications of boosting a lower voltage. By doing so you will introduce a lot of new problems not the least of which is the electromagnetic noise you will be adding and needing to deal with. Efficiency is also an issue.
But in the end, there is a lot of to and fro on the decision so this question really comes into the opinion ranks.
Trevor_G
  • 46,675
  • 72
  • 154
    Another argument to make: A boost converter has <100% efficiency. In fact, the cheaper it is, the less likely it is to reach even 85% efficiency for e.g. a 1.5V -> 9V conversion. If you have the space, and you need 9V, why not get it directly? – Marcus Müller Aug 08 '17 at 14:06
    Thank you for your answer @Trevor. I did not intend this to be an 'opinion based' question, as I was trying to word it to ask what advantages are there and where would they be used rather than 'what is better, please discuss' which I could have done a better job of I suppose! I like the point about the sensors and transducers – MCG Aug 08 '17 at 14:07
  • 28
    I respectfully disagree with your first sentence. A AA cell can be a battery. A lot of devices only take one AA. – trpt4him Aug 08 '17 at 19:28
  • 17
    @trpt4him Also, they sell "AA batteries", not "battery refill AA cells". Surely when discussing a circuit you can call the part with the AA's in it "the battery", but when discussing the objects you buy at a store and use to power that circuit, I think they are "batteries". – Darren Ringer Aug 08 '17 at 19:33
    @trpt4him you have to look up what battery means. http://www.dictionary.com/browse/battery – Trevor_G Aug 08 '17 at 19:34
    @DarrenRinger just because it's a popular error.. does not make it right. – Trevor_G Aug 08 '17 at 19:35
    LOL @DarrenRinger u r right... I hate popularisms.... I could argue the English that Battery is a collective plural... but what would be the point – Trevor_G Aug 08 '17 at 19:37
  • @Trevor I agree in principle, but definition 1b of the link you provided is "cell" - the words can be totally synonymous. Words don't really have a single definition that must be enforced in all contexts, or am I misunderstanding your argument? – Darren Ringer Aug 08 '17 at 19:38
  • @DarrenRinger the issue comes when your device is powered by two or more AAs.. What you really have is "A Battery of AAs". "Two AA Batteries" does not make sense... We could argue it forever, I just recall getting yelled at by the electrical professor for using the wrong name. – Trevor_G Aug 08 '17 at 19:41
  • 36
    In non-EE English, "AA battery" and "AA batteries" are phrases used by people and in advertisements (at least in the USA) every single day. "Two AA batteries not included" appears on so many packages. https://en.wikipedia.org/wiki/AA_battery – Todd Wilcox Aug 08 '17 at 19:54
  • I did look it up. https://www.merriam-webster.com/dictionary/battery – trpt4him Aug 08 '17 at 20:05
  • 42
    I agree that a battery is an array of cell(s). I see cells as a component of a battery; my car battery has 6. I do not agree that the term "battery" cannot be used for single-cell devices, just as I do not agree an array requires 2 elements to declare. A 1-cell battery is simply a cell which has additional finishing and packaging to render it fit for direct consumer use. – Harper - Reinstate Monica Aug 08 '17 at 21:21
    If I have 100 9V's, I have a "battery"? Then, what if I remove 1/2 of them into two piles. Do I have two "batteries" or two 1/2's of a battery? It is kinda like a hole. You can't dig 1/2 a hole. Thus, "battery" is both singular and plural. Usage of "batteries" is clear for anyone who reads it. – MikeP Aug 09 '17 at 01:19
    Why don't manufacturers integrate the 6 cells? Both kinds of 9v batteries I've seen (ones with 6 stacked rectangular cells, and those containing 6 AAAA cells) have a lot of empty space, and extra weight in the form of cell casings. Couldn't we get much better lifetime if we better used this space? – Alexander Aug 09 '17 at 05:30
  • 43
    AA is not a battery or a cell. It's a size. Whether it is comprised of a single cell or multiple cells seems like an implementation detail that people using it don't need to care about as long as other observable characteristics remain the same. – jamesdlin Aug 09 '17 at 05:57
    1s1p battery packs FTW. – Dampmaskin Aug 09 '17 at 13:43
    Nobody is really wrong in this debate of battery vs cell. Strictly and historically speaking, a battery is a set of cells in series, and is primarily defined as such in the OED. In modern usage, the word battery has come to be broadened to include all single- and multi-cell devices, as is acknowledged in the OED's definition, reflecting the real-world usage of the word by just about every manufacturer of cells/batteries, makers of the products that require them, and the people who use them. – Daniel Austin Aug 09 '17 at 16:03
    @DanielAustin but where will people direct their furious anger and rage? This is literally the most important problem anyways. – Nick T Aug 09 '17 at 17:51
    People - IT DOESN'T MATTER - jesus... – Digital Lightcraft Aug 10 '17 at 09:23
  • @NickT Fantastic use of "literally". I'm glad that word now means essentially everything. – JMac Aug 10 '17 at 11:52
  • literally everything. ^^
  • – Dampmaskin Aug 10 '17 at 12:27
  • How many soldiers are in a "troop"? – richard1941 Aug 10 '17 at 17:37
    For anyone who does not want to rip open a 9V battery, it looks like six pieces of PEZ candy - but DON'T EAT IT! 1, 2, 3 – uhoh Aug 11 '17 at 08:15
    Battery vs. Cell. Battery should be a collection of cells, just as a flock is a collection of sheep. But people don't really follow such rules. I'm sort of in favour of the dictionary telling us how to speak (prescriptive), rather than reporting how we speak (descriptive). Otherwise, why do we need to learn English at school at all? However we talk would already be correct. I'm surprised "noocular" isn't now listed as a correct pronunciation for the word "nuclear" after several presidents of the USA got it wrong. – Reversed Engineer Aug 11 '17 at 10:39
  • "contains six (size-AAA) 1.5V cells" - I don't think it's AAA size, those have diameter of 10.5 mm, and I can't see how you'd fit six of those into a 26.5 mm x 17.5 mm cross-section of PP3. – Dan Mašek Aug 11 '17 at 13:19
    @DanMašek, thanks for pointing out that erroneous edit someone did.... – Trevor_G Aug 11 '17 at 13:23
  • Google defines a battery as one or more cells as does my copy of the Oxford English dictionary so I think its OK to talk about an 'AA' battery. This is not the English language and Usage Stack Exchange site so can we stick to Electrical Engineering please. – Warren Hill Aug 11 '17 at 15:04
  • Wouldn't a buck converter be fine with a 9VDC battery? The big concern I see with going down to 5VDC is if you're using an LDO regulator and burning off 4V*current as waste heat in the regulator. – Cloud Aug 11 '17 at 16:32
    In ancient times, Euclid did not consider 1 to be a number, because it was not a multitude of ones. Nowadays, of course, we know better. – Bill Dubuque Aug 11 '17 at 20:32
  • As usual, it depends on context. In a UPS room, there is a diesel generator, lines of glass boxes and an inverter. All the glass boxes together are a 'battery'. Each line of boxes is a 'string' and each box is a 'cell'. In that context, the fact that each 'cell' is 12V and has six 2V lead-acid sub-units is irrelevant. These terms are overloaded, like 'static' in C and C++ ;) – Martin James Aug 13 '17 at 15:27
    AA is not a battery or a cell or a size. It's a size specification. Whether it is implemented exactly, slightly smaller, or slightly larger, the actual size is just an implementation detail of the specification. People using it don't actually care about how it's implemented as long as it works. – Nat Aug 13 '17 at 18:48
    AA is not a battery, a cell, a size, or a size specification. It stands for Alcoholics Anonymous for goodness sake. You're all wrong. Also I'm sorry I started this... – trpt4him Aug 16 '17 at 16:32
  • What about using a tiny SMPS? – Demi Oct 01 '18 at 23:44
    Why is having a wide voltage range a good thing? – user253751 Nov 22 '19 at 16:50
  • "First a AA is not a battery.. it's a cell." is just unnecessary nitpicking. The question author asks for the reason for using 9V batteries, unsolicited and tangential schooling about terminology's minutiae. And from Wikipedia: "[a] battery is a source of electric power consisting of one or more electrochemical cells with external connections for powering electrical devices." (emphasis mine). – Chad Branzdon Jun 24 '23 at 01:05
