I'm experimenting with two coils. I drive them with two MOSFETs and one consumes around 1A and the second ~0.7A (12V power supply able to deliver 15A). While the coils work with permanent magnets and repel and attract them as opposed, I observe no interaction when I bring them close together. I mean not even a hint of movement. Unfortunately I don't have a way to take a picture of these, the first one is around 1 cm diameter and 50 turns and the second around 2cm diameter and 50 turns. Is the power very limited? How should I estimate electromagnet force in Tesla units, and how to measure permanent magnet (small neodymium) magnetic force?
John Am
  • 749
  • 26
There will be some interaction but very small compared to using a permanent magnet and a coil. The magnetic field produced by the coils will be individually weak hence no apparent interaction but the magnetic field strength from a permanent magnet will be massive in comparison and this is enough to produce a noticeable effect.
Have you tried winding the coils around an iron core to increase the flux density? Here's a formula that should give you some general idea about the force from an electromagnet acting on a piece of magnetizable metal: -
Force = \$(N\cdot I)^2\cdot 4\pi 10^{-7}\cdot \dfrac{A}{2g^2}\$
  • F = Force
  • I = Current
  • N = Number of turns
  • g = Length of the gap between the solenoid and the magnetizable metal
  • A = Area
Detail above taken from here
Andy aka
  • 456,226
  • 28
  • 367
  • 807
  • Thanks. Yes, I tried to place an iron bar inside both of them. I still haven't observed even a tiny bit of force between them. Does a permanent magnet create so much greater magnetic force? With the 1A coil I can attract the permanent magnet from 3 cm away. – John Am Aug 06 '17 at 11:13
    A permanent magnet will generate a massively greater field than the coils you have mentioned. Electromagnets in relays have thousands of turns. – Andy aka Aug 06 '17 at 11:15
    If you (as in the OP) have a relay lying around, take it apart and see how much force it generates compared to your coils... – Solar Mike Aug 06 '17 at 11:16
  • By using the application you mentioned I calculated for coil#1 ( i: 1.0A, area: 0.785 m^2, n(turns): 50, g (length): 0.01m) /// coil#2 ( i: 0.7A, area: 3.141 m^2, n(turns): 50, g (length): 0.01m ) and I get 12.337N and 24.181N respectively. Check the length is 1 cm if I put it 1mm ( g(length) = 0.001 ), I get 1233N and 2418N for the second coil. How to measure the force of the small permanent magnets? – John Am Aug 06 '17 at 11:37
    How much area? Think again and work in metres not cm. Force can be measured by a spring balance but you need to define your experiment to get meaningful answers. – Andy aka Aug 06 '17 at 11:43
  • Ok, thanks. I get now 0.123N and 0.493N for 1 cm distance and 12.252, 49.323 for 1mm distance. Does it make sense? – John Am Aug 06 '17 at 11:47
    @JohnAm To reason in a practical way about measurements in newtons think of this: the force of 1N is the force that you would perceive as weight if you held a mass of about 100g in your hand. – LorenzoDonati4Ukraine-OnStrike Aug 06 '17 at 13:12
