Problem
How does one increase the resolution of a SPICE plot? My sinusoidal signal doesn't look continuous, it looks very 'pointy'. I am using MACSPICE3 to simulate a non-inverting op-amp by using a dependent source (VCVS). Changing the step parameter of the tran command has not helped.
I understand that results data is stored in a construct called a plot, which is comprised of vectors. Is this pointy phenomena linked to the data in these constructs, or the graphical representation?
Example of a pointy plot
Pointy SPICE plot
Netlist
Basic Non-Inverting OpAmp
V1 2 0 AC sin(0 10 50 0 0) DC 0
RBogus 2 0 10K
e 3 0 2 1 999K
R1 3 1 10K
R2 1 0 10K
.control
delete all
tran 1.0ns 100ms
plot v(1) v(2) v(3)
op
display
print all
show all
.endc
.end
Note:
RBogus exists to create a closed loop for the ac source.
DWD
  • 323
  • If it's generic SPICE syntax, try .tran 0 100m 0 10u. 1u is the timestep. – a concerned citizen Jun 23 '17 at 04:56
    @A Concerned Citizen, Thanks for your input. Macspice uses the syntax: .TRAN TSTEP TSTOP [ [ TSTART ] TMAX ] [ UIC ] So my analysis should step at increments of one nanosecond, for 100 milliseconds. I have just learned that TMAX and the TSTEP work in conjunction with each other. I will post an answer – DWD Jun 23 '17 at 07:47
  • @aconcernedcitizen, which version(s) of spice would you recommend? Macspice doesn't seem to have the support that LTSpice or PSpice have for instance. Would appreciate your thoughts. – DWD Jun 23 '17 at 08:02
    Glad it worked out, but I wouldn't recommend one SPICE over another simply because that works for me. De gustibus... The best tool in the world is the one that suits you best. – a concerned citizen Jun 24 '17 at 06:10
The syntax is
Changing
tran 1.0ns 100ms
To
tran 1us 100ms 0 1us
has solved the issue. In the user guide, note that the TSTEP doesn't exclusively control the step size. TMAX must also be set. The boldface text explains why.
  • TSTEP is the printing or plotting increment for line-printer output. For use with the post-processor, TSTEP is the suggested computing increment.
  • TSTOP is the final time
  • TSTART is the initial time. If TSTART is omitted, it is assumed to be zero. The transient analysis always begins at time zero. In the interval , the circuit is analyzed (to reach a steady state), but no outputs are stored. In the interval , the circuit is analyzed and outputs are stored.
  • TMAX is the maximum step-size that SPICE uses; for default, the program chooses either TSTEP or (TSTOP-TSTART)/50.0, whichever is larger. TMAX is useful when one wishes to guarantee a computing interval which is smaller than the printer increment, TSTEP. enter image description here http://www.macspice.com/ug/sec4.html#s4.3.9
DWD
  • 323
