I have this Bluetooth receiver. The battery is not holding a lot of charge anymore so it's become pretty useless. I can't plugin the device and use it at the same time, so I was wondering if I could remove the battery and use the cables that originally connected the battery to directly plugin the device. The battery is YJ402025 Li-Po 3.7V 160MAh. USB provides 5V so not sure if that's going to be an issue... I could take pictures of the device's circuit board if that would be helpful.
kat
  • 103
If you do replace the battery with a USB supply, you should drop the 5 volts down to something closer to 3.7 volts. You could do this with a low drop out 3.5 volt regulator such as the MC33269T and a small heatsink or you could put two or three 1N400X type diodes in series with the positive lead of the USB supply.
Glenn W9IQ
  • 5,564
  • 17
