While programming an ATtiny or ATmega, avrdude prints the device signature, in this example it is an ATtiny.
avrdude: Device signature = 0x1e910a
Can I read this signature on a running device using C++ code (avr-gcc)? For ATmega1280 there is a chapter 29.6.10 writing about it, but I'm a bit puzzled by how I can code it in C++.
I want to be able to make the device send its device ID back to the controlling PC, so the PC can make decisions on it.
tyblu
  • 8,207
  • 41
  • 70
jippie
  • 33,221
  • 16
  • 95
  • 161
  • This question is closely related: http://electronics.stackexchange.com/questions/58386/how-can-i-detect-which-arduino-board-or-which-controller-in-software/58388#58388 – jippie Feb 20 '13 at 21:28
You can use these macros that get defined automatically when you include <avr/io.h>:
SIGNATURE_0
SIGNATURE_1
SIGNATURE_2
For ATmega1280, they're defined as:
/* Signature */
#define SIGNATURE_0 0x1E
#define SIGNATURE_1 0x97
#define SIGNATURE_2 0x03
in iom1280.h (which is automatically included through <avr/io.h> when you compile code for the m1280)
For example, this will send the three bytes via UART:
uart_putc(SIGNATURE_0)
uart_putc(SIGNATURE_1)
uart_putc(SIGNATURE_2)
If you truly want to read the fuses, you'd need to use boot_signature_byte_get macro from <avr/boot.h>
ksk
  • 316
  • I used boot_signature_byte_get( 0x00 ), boot_signature_byte_get( 0x02 ), boot_signature_byte_get( 0x04 ) – jippie May 12 '12 at 12:42
