I have designed multiple small PCBs for personal projects, and have used USB ports many times for an output. I have always wondered if it is a good idea to connect the two mounting holes for the USB port together via traces.
Is this a good idea or does it even matter?
Picture of USB footprint: USB footprint
Benjamin Owen
  • 189
Mechanical reasons, the more copper around connectors the better so if your worried about it ripping off of the board more copper will give you more leeway before it comes off the board.
You will get half of the inductance if you connect both so if your worried about radiated emissions out to the cable or conducted emissions to your board (assuming you have one ground and not a shielded ground.)
The shield is already tied in the case so the yellow trace is redundant.
Voltage Spike
  • 82,181
  • 41
  • 84
  • 220
