I'm having issues setting the state of any of the D Flip Flops, I have jumpers and a multimeter to work with. does the clock pulse have to more precise than touching the jumper to +5v?
74s374J
data sheet
    Yes, you need a switch debounce circuit. See this answer https://electronics.stackexchange.com/a/18820/35022 – MarkU Apr 20 '17 at 00:36
The 74S374 is a bipolar TTL part. Bipolar TTL inputs source current, so must be pulled low by a very low value resistor, or more often a switch to ground, to guarnantee that the input will be seen as a Low. An open (unconnected) input will usually be seen as a logic High, but it is good practice to use a pull-up resistor to ensure that the input will be seen as High.
If you leave the clock input open, it will be seen as a High, and connecting it to Vcc will just make it Higher - it will never be Low, so no Low->High transition to clock the flip-flops.
Peter Bennett
  • 59,212
  • 49
  • 132
Maybe. The clock pulse has to go from a low level, < 0.8v, to a high level, > 2v, to strobe the flip flops. If the clock input was an open circuit before you hit it with 5v, you didn't have a low to high transition. You had a high to higher transition, which wouldn't do anything.
You'd be better off connecting the inputs to 5v through a resistor, then strobing by touching the jumper, also connected to the input, to ground.
Usually you will get many strobes (bouncing)by the jumper-touching. For what you seem to be trying to do it won't matter.
