The cheapest class of GPS receivers is what we all have inside our smartphones etc.
Then we have devices like this U-blox.
In the end there are professional GPS like this SPAN combined with INS (IMU).
The latter one is basically 1 box including support for GPS+Antenna+INS.
It's understood why the INS component is expensive (MEMS gyro etc.), how the INS correcting the GPS and same with the Antenna.
This raising the question what is the difference solely in the GPS component inside the professional expensive device versus the cheaper one? Because if it's essentially the same, one can take $50 GPS receiver and by adding Antenna get same result like buying the expensive professional GPS...
Thanks,
michael
  • 145
    IMO you are comparing apples to oranges. Even if you weren't, "cheap vs expensive" is an unending debate in any field. – Wesley Lee Mar 21 '17 at 13:18
  • @WesleyLee Why apples to oranges? Inside the professional device you do have pure GPS component. – michael Mar 21 '17 at 13:29
  • I disagree that smartphones have the cheapest receivers, because smartphones are used in suboptimal conditions (indoors, bad antenna) you might need a better, more expensive receiver to get decent performance. 2) the price of product does not always relate to the price of the components used. 3) Professional does not always mean "better components", it can also be same component but better antenna, more optimized software, better support. 4) what do you mean by "pure GPS component" ? Is a GPS receiver in a cheap phone not "pure" ? And if so, why ? (show facts, no assumptions).
  • – Bimpelrekkie Mar 21 '17 at 13:32
  • @FakeMoustache Inside the professional box you have {pure GPS, INS, Antenna}, in "pure GPS component" I simply refer to all the electronics related to the functionally of the GPS, and not the INS and the Antenna. – michael Mar 21 '17 at 13:40
  • @FakeMoustache Smartphone can cost $100 and the GPS is not the most important & expensive component there. ublox is $50. The professional staff can be even $30,000. Yes, price is a function of marketing & demand. However difference between $50 to $30,000 is more that that. – michael Mar 21 '17 at 13:43
  • However difference between $50 to $30,000 is more that that. Again, you're making assumptions. Of a professional device, less units will be sold so development cost per unit is higher. Professionals require support for longer, supporting a device costs money. Who are you to say that this does not explain the price difference. – Bimpelrekkie Mar 21 '17 at 13:47
  • Apples to oranges because U-blox is a module for PCB mount, while the SPAN is a solution in which the machined enclosure alone is going to cost more than the whole U-blox itself, not to mention connectors, etc. – Wesley Lee Mar 21 '17 at 14:09
  • Consider the price difference between military and COTS components. The military rated ones are not more expensive because they are "better", but often simply cause they're "ruggedized" + the point that FakeMoustache made about development costs divided per units sold. Your question sounds a lot like "Why does a luxury watch cost orders of magnitude more than a cheap digital watch? The components inside them do not justify this difference". – Wesley Lee Mar 21 '17 at 14:13
