I measured a few laptop AC-to-DC adapters. They have 1 MΩ between the GND pin (goes into the laptop) and the earth prong (into the wall).
Desktops are grounded directly to earth: 0 Ω.
Why this difference?
The diagram below is based on the one you provided in your duplicate of this question. Not only are duplicates not allowed they are a very bad idea as exactly what has happened here occurs - information is spread over two questions.
Your diagram was not of a power supply but of a line filter and it was left for right swapped.
I have rearranged it here and changed it to represent a power supply.
AC mains is connected at left.
DC low voltage is supplied at right.
The two series capacitors are the "Y" noise suppression capacitors required by most regulatory authorities.
IF the green dotted ground connection is connected then the centre point of the two capacitors is at ground, as is intended by the designers.
IF the green dotted ground connection is NOT connected* then the centre point of the two capacitors is at mains/2 at an impedance set by the two capacitors.
If a 1 megohm resistor is connected as shown it provides an electrostatic "bleed" from the laptop low voltage ground to either mains ground or mains/2. Either will discharge electrostatic charge.
If the 1 megohm resistor is replaced by a hard link then if the green dotted earth connection is absent* then the laptop ground will be connected via the capacitors to Vmains/2. The impedance is low enough to cause very unpleasant but technically not life threatening shocks. It is also entirely adequate as a means of semi-randomly destroying equipment connected to the laptop.
*Mains ground may not be connected because a 2 wire power cord is used, or a 2 pin plug is used, or a 2 wire mains socket is used, or because Murphy wanted to have fun. Using the 1E6 resistor rather than a hard link tends to give the best of all worlds in most cases.
Added 2022 - notes from comments:
A 0 Ohm connection )(ie Vout-ve = main ground) is used in some cases and when 2 x input Y capacitors are used from 2 x line connections to input ground AND when a 2 wire cord or otherwise unearthed supply is used you get the situation I described in my commments to this duplicate version of this question. Then Vout-ve floats at half mains with about 1 nF coupling (typically) and gives users nasty nips (AMHIK*) and may damage grounded equipment it is connected to.
(AMHIK* - Ask Me How I Know] –
An isolated secondary provides more protection generally against various issues such as Murphy destroying the primary side of the power supply mit spitzen sparken, and main voltage issues.
WITH NO connecting resistor the secondary can float at electrostatic voltages and even if the laptop is properly designed, peripherals may not be and eg mouse, general USB equipment, external monitors and more are at risk. While it would be "nice" if all such devices were 'properly designed', competent designers may go the 2nd mile and add a bleed resistor.
There is no certainty that worst case electrostatic charge will not exceed standards models. Laptops may have substantial common grounded interconnecting metalwork and you can usually expect continuity between both the expressly grounded outers of some connectors and the metal mountings or most other connectors.
I just took the nearest laptop [HP 2540P Elitebook] and tested continuity of metal parts on external ports & parts. "Grounded" continuity exists between metal parts on 11 of the 13 connectors (2 have no accessible metal), the 12 or so base screws plus the DVD drive large metal plate plus the DVD metal slide rails. Sitting this laptop on ones lap with a shunt linked supply and no ground on the power lead would lead to very annoying shocks (AMHIK) and potential (pun noticed) damage to or destruction of peripherals (AMHIK). –
I have here a Dell laptop power adapter where I measure 0 ohms between the mains ground and the ground of the low voltage output.
And I also have an Acer adapter where there is 1 Mohm like you measure.
So it is not a "universal truth" that all laptop adapters are grounded via 1 Mohm.
Indeed all desktops are grounded via 0 ohms.
For desktops the 0 ohm makes sense, if for whatever reason the metal case becomes live a 1 Mohm series resistor will not make enough current flow to ground in order to protect you, the user, when you touch the case or anything connected to it. Nor will it trip the RCD or earth leakage circuit breaker.
Remeber: metal case so 0 ohm grounding is required !
Laptops are a different class of devices as there is no mains voltage present in the laptop itself. The power adapter has a plastic housing so it cannot become live so 0 ohms grounding is not needed for safety.
This leaves it up to the manufacturer to make the choice of not grounding the low voltage side (mains side uses a figure-8 type power connector) or ground via 0 ohms like in a desktop or ground via 1 Mohm.
My guess for the reason to ground via 1 Mohm instead of 0 ohm might have to do with ESD discharging. When you are electrically charged and touch a metal part of the laptop, the discharge would flow through the laptop's ground. When this ground is 0 ohms you might feel a "tingle". With the 1 Mohms the current will be limited so the discharge will still take place (and take slightly longer but still only a fraction of a second) but you would not feel it.
