54
In many Power over Ethernet (POE) setups the transmission voltage is 48V or slightly more. While higher voltage has obvious efficiency advantages, how safe it is? Is there any risk of electrocution when accidentally exposed, in particular to children? Such wirings lack the protection that is used for 120/230V, and frankly the difference between 48V and 120V doesn't seem to be that significant.
Grebu
  • 535
  • 17
Petr
  • 761
  • 14
    What's a POE, and why would it be exposing itself to children? – Bruce Abbott Nov 06 '16 at 07:54
  • 14
    @BruceAbbott Power over Ethernet. I'm concerned about accidental exposure. not anything on purpose. The Ethernet cables aren't perceived as dangerous by people and lack the protection 120V/230V cables and systems have. – Petr Nov 06 '16 at 07:58
  • 19
    The original POTS (Plain old telephone) was a 48V system and that lasted for almost 100 years. – crowie Nov 06 '16 at 07:59
  • 17
    @crowie. The ringing voltage of the POTS were higher and could give you a nice shock. – Decapod Nov 06 '16 at 10:05
  • @Decapod, nominally 90Vac@20Hz US? The 75Vac@25Hz here in the UK certainly stings but is a bit hard to get at unless you dismantle the phone, while the DC is barely a tingle on sweaty hands – Chris H Nov 07 '16 at 09:30
  • 24
    How many Watts do you expect your kids to negotiate over IEEE 802.3? – Dmitry Grigoryev Nov 07 '16 at 15:15
  • In the UK the phone-end of phone cords used to be designed so it needed a tool to disconnect (typically it used a RJ style connector with a shortened tab) but more recent phones seem to use cords with regular RJ connector. – Peter Green Nov 08 '16 at 02:40
    Some data links over copper (HDSL/CWSS etc.) use up to 120v which from memory is the highest they can go on public phone lines (in the UK) without safety implications - not least for the unwary engineer probing connections down the line. I think on dedicated cables (not shared with POTS) they can go higher but very little actually does. @crowie - POTS is still very much alive despite its death being "imminent" for the last 30-40 years or so. – John U Nov 08 '16 at 12:39
  • @JohnU Yes I know POTS is still around but its changed over recent years. I was referring to the original 600ohm -48V line POTS. – crowie Nov 08 '16 at 14:52
  • Skin resistance is irrelevant if and until the current does get through the surface barrier (skin usually). ie it could be 1 megohm and be hardly different, but if skin puncture occurs things "may change". 12V has killed in VERY exceptional cases. I would not trust my life to 48V, especially across my chest. I have read the "expert analysis" on which the latest ELV requlations are based and would still be wary. | 48V on a high humidity day causes annoying "bites" across the skin of your hand when working on a telecom 50V wiring frame. (Holiday job decades ago). – Russell McMahon Nov 08 '16 at 18:32
  • It's always the amps that kill you scnr – user1129682 Nov 09 '16 at 13:32
    @crowie - what's changed about POTS then? Last time I was in a telephone exchange everything was still -48v and your old rotary-dial phone is still supported. – John U Nov 09 '16 at 14:15
  • @JohnU POTS is now digital (see DS-0 64kbit) and has been for many years. Yes the physical lines are 48 volt and the old rotary dial style handsets are still supported though as part of the standard but they go through an ADC at the exchange and then converted to digital frames. In addition not quite so old DTMF handsets are also supported. The original POTS was an analog system. – crowie Nov 10 '16 at 12:13
    @crowie - not wishing to start an internet argument but POTS is POTS and the digital system that delivers / processes / transmits it is kinda irrelevant. You may as well say POTS is fibre-optic because that's how it travels for most of its journey... POTS is no more digital than my postman is a pilot because he delivers airmail. – John U Nov 10 '16 at 13:14
    @JohnU I would say its very relevant sir. The Plain Old Telephone Service is not just the 'postman' as you put it. Its a digital system with analog interfaces. Anyway I only mentioned it as an example of a 48V system thats worked 'relatively' safely for many years lets just leave it at that. – crowie Nov 10 '16 at 13:44
9 Answers9
81
120V is 2.4 times higher than 48V - hardly what I would call 'not that significant'. 120VAC is even worse, for two reasons:-
  1. 120VAC has a peak voltage of 170V, 3.5 times higher than 48VDC.
  2. The 'electric shock' feeling occurs on every peak of the AC waveform, whereas with DC it mostly occurs on initial contact.
It only takes about 30mA of 60Hz AC current through the heart to cause fibrillation, compared to 300-500mA of DC current. The 'let go' current (above which you cannot let go of a grasped conductor) is 4 times higher for DC than AC. So that means you need 4-17 times more DC voltage to get a fatal shock.
Combine 2.4 times higher voltage with 4-17 times higher susceptibility, and 120VAC is approximately 10-40 times more deadly than 48VDC.
But is 48VDC safe in an Ethernet cable? Provided you don't strip off the insulation and poke the bare wires into your flesh, the chances of getting a fatal electric shock from it are negligible. I know from personal experience because I was a telephone exchange technician for 15 years, and regularly worked on live equipment with exposed contacts. The biggest DC shock I ever got was a light tingle when grasping a 50V bus bar (90VAC ringing was a different story...).
Bruce Abbott
  • 56,322
  • 48
  • 93
  • 16
    Then there is this old story. Unclear whether it is fictitious, but it could be true: http://www.freedomisknowledge.com/otw/stuff/pissingandmoaning.html – Richard Crowley Nov 06 '16 at 09:14
    I can remember when I was quite a bit younger, handling stripped phone wiring in preparation to connecting them to screwdown terminals. The 48 volts DC on-hook I didn't feel in the least. However, when the phone rung, the 90 volts AC ringing voltage gave me quite a shock. – DoxyLover Nov 06 '16 at 10:09
    @RichardCrowley heartfelt thanks for that. I cried. :-) (and then the telephone rang) – Sredni Vashtar Nov 06 '16 at 23:00
  • I used to do a lot of telephone installs. I wasn't too fond of my connections happening at exactly the same time that the line happened to ring, but it wasn't terrible. More of an annoying poke. – Brian Knoblauch Nov 07 '16 at 18:39
  • Another victim of ringing phone contacts here. Clearly it's not something people forget quickly. – Todd Wilcox Nov 08 '16 at 04:05
  • The reference you use for 'let go' current sais nothing about the difference between DC and AC for that measure, just the level at wich you can feel it. So no 4x increase in that i'm afraid:https://books.google.nl/books?id=reRseI_kFlYC&pg=PA204&lpg=PA204&dq=%27let+go%27+current+(above+which+you+cannot+let+go+of+a+grasped+conductor&source=bl&ots=5jzvuL533U&sig=8_3tjehttkAbTdXlECbkN9f8AFM&hl=nl&sa=X&ved=0ahUKEwi3z6mY35jQAhVFxxQKHVVTAAkQ6AEIQDAE#v=onepage&q=%27let%20go%27%20current%20(above%20which%20you%20cannot%20let%20go%20of%20a%20grasped%20conductor&f=false – J.A.K. Nov 08 '16 at 08:38
    Apart from dismantling, stripping and poking a wire in bare flesh, a child can simply put an ethernet cable end directly in his/her mouth. The difference between POE and POTS and regular electricity cables is that the POTS and regular electricity cables have plugs that cover most of the conducting metals. POE with RJ45 not much so. – nl-x Nov 08 '16 at 14:49
    @nl-x most popular phone plug is RJ11, same style as as RJ45. Simple fix for both cases is to break the tab off the plug so babies can't unplug the cord. – Bruce Abbott Nov 08 '16 at 17:40
  • were talking (power over) ethernet. so rj45. also breaking the tab means easier unplugging. (too easy) – nl-x Nov 08 '16 at 17:42
  • @J.A.K "At 22 mA, more than 99% of adults will not be able to let go... with direct current, there is only a feeling of shock when the circuit is made or broken... Below 300 mA DC rms, there is no let-go phenomenon" https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2763825/ – Bruce Abbott Nov 08 '16 at 17:51
    @nl-x not the whole tab, just the bit that sticks out. – Bruce Abbott Nov 08 '16 at 18:04
  • I remember feeling the 48v on POTS when I was stripping wires with my teeth as a teenager. The return wire touched my cheek and my tongue suddenly felt hot. I suspect you might feel something similar if you put one end of the RJ-45 in your mouth. If there's no ground reference on the signal, that would only light up your mouth. If you're grounded, though, it could pass through your heart, but only to the current supplied by the source power supply. Remember it's the current that kills you; not the voltage. – Phil Hord Nov 08 '16 at 18:36
  • I would be extremely careful about giving hard numbers on what will cause fibrillation. 300mA DC through heart is huge and will definitely cause the heart to clench which will still kill you stone cold dead although it's far more likely the heart will resume pumping after being clenched up rather than fibrillation. I referred to the relevant IEC standard and anything over 25mA DC and 5mA AC is no longer considered safe for people working with electricity. – Barleyman Nov 09 '16 at 02:08
35
48V is the practical and LEGAL definition of the maximum voltage to be considered "low voltage" and intrinsically "safe". Certainly 48V delivered UNDER your relatively insulating skin surface could kill you if delivered in the "right" place. But we are assuming people aren't walking around with subcutaneous electrodes exposed to accidental contact with "LV" wiring. 48V is reasonably safe for most people under normal conditions.
As observed by @crowie, the original (and current) technology wired public telephone system operates on 48V for over 100 years. That old telephone technology is very likely the precedent for establishing 48V as the legal limit.
Richard Crowley
  • 14,460
  • 37
  • 20
    Just to be pedantic, here in the UK at least, Low Voltage is anything under 1000V. Hence for instance 960V battery sets called Low Voltage, ouch. Under 50V is "Extra Low Voltage", and if it is not ground referenced and double insulated and various other specifications, it's "Safety Extra Low Voltage", precisely because you can't get a shock by touching one of the wires. – Ian Bland Nov 06 '16 at 10:41
    @IanBland: not correct - there are very different definitions used in electrical power transmission/distribution, vs electrical safety codes. You wouldn't transmit power at 1000V into a residential house. – smci Nov 06 '16 at 12:38
    @smci There isn't 1kV transmission, period. It goes from 230/415 up to 3.3kV, then 11kV on the UK distribution system. But terminologically, a local battery set or generator working below 1000V would be termed as low voltage. Above that, anyone working on it would have to be HV qualified. It's a pretty good breakpoint because it's above that kind of voltage that you need a specialised working and safety skill set. – Ian Bland Nov 06 '16 at 13:58
  • 18
    @IanBland In microelectronics we call anything above the power rail "High Voltage". Even 5 V can be high voltage. Just a matter of context... – bogl Nov 06 '16 at 16:11
  • @IanBland Similarly I have an LED strip that uses 9A (at 5V), which is "high current" compared to the Raspberry Pi that's controlling it. But 9A through mains wiring is nothing particularly special. – user253751 Nov 07 '16 at 00:24
    IanBland is using the definition laid down by the International Electrotechnical Commission, which seems fair to me. https://en.wikipedia.org/wiki/Extra-low_voltage – nekomatic Nov 07 '16 at 11:17
    @smci: Ian Bland is correct. The electrical safety codes (IEE 17th edition) in the UK use "Low Voltage" to refer to 220V (single phase) and 415V (three phase). 50V is ELV, or SELV as appropriate. See https://en.wikipedia.org/wiki/BS_7671 – Martin Bonner supports Monica Nov 08 '16 at 14:11
  • The least voltage I've ever read of being fatal without subcutaneous electrodes was 32 volts DC. – user6030 Nov 15 '16 at 01:49
27
No death by electrocution going to happen
48V is considered "safe", and that is for good reason.
First, the impedance of the human body at 50V is around 45kΩ (though measured on adults). While children are overall smaller and thus should have slightly lower impedance, it's the skin resistance which makes up 95% of that impedance (internal body fluids are pretty good conductors), so the size doesn't matter all that much.
(Note how body impedance is a funny thing, it goes down rapidly as voltage goes up, at 240V it's 10-15 times lower!)
Further, an electric current needs somewhere to go, obviously. No closed circuit, no current. That's why birds sitting on an overland line aren't fried.
These 48V are 48V against ground. In all likelihood, the next closest thing to "ground" that you have contact with is "parquet/laminate" or "floor tiles" or something similar, in other words, resistance around infinite, current zero.
Even touching the hot wire on 240V has a good chance of "not much bad stuff happening", if you wear shoes and aren't precisely standing in a puddle of water (although for obvious reasons I wouldn't advise trying your luck!).
Let's assume the absolutely worst case: a child puts one finger onto the ground pin on a wall plug, and sucks on the PoE cable (looks edible, doesn't it!). Against all odds, the PSE is broken or heftily non-compliant and instead of supplying 10.2V/4mA max as per default, it supplies full operational voltage, and unlimited current. Or, it takes some random pattern that the child accidentially made for a valid negotiation, whatever.
Also, for an unexplainable reason, the current doesn't short circuit over the data wires (the likely thing to happen would be exactly that, a little spark on the child's tongue, and the child dropping the cable in a fright).
Let's just say there's actually 40V on the wire, and the current "decides" to go through the child's body, against all reason and against the laws of physics.
Cable-in-mouth will eliminate one skin barrier and thus approximately halve the body impedance. That's 22.5kΩ remaining. Let's round down to 20kΩ to be sure. No, you know what, let's be outrageous, and say 10kΩ. 48V/10kΩ = 4.8mA.
Which... is harmless even for alternating current. It takes about 8-10 times as much alternating current (of a frequency in the critical 50-60Hz range) to stop the heart.
Now, on top of that, PoE doesn't have alternating current, it's DC. So the scary bit about cardiac arrest doesn't even apply.
Of course, DC can in principle cause adverse effects other than stopping the heart (think of a surgical electro knife, or the "electric chair"), but given voltages in the two digit range and currents in the single-digit milliampere range, this simply isn't going to happen (but even if it was, it would primarily be local burns, not life threatening).
Damon
  • 459
    48V DC melts-in-your-mouth goodness will probably make a child, you, or most people have enough of an involuntary and violent reaction to facilitate a secondary accident (eg falling off a ladder).... – rackandboneman Nov 07 '16 at 08:47
    @rackandboneman: That's perfectly true, but it is true for a million other harmless things as well. A barking dog, a popping balloon, or the doorbell could just as well facilitate a secondary accident. Being of the more easily agitable type myself, I can confirm having had hot coffee more than once on my pants because someone unexpectedly rang the doorbell. – Damon Nov 07 '16 at 08:56
  • 25
    Note that PoE requires negotiation before 48V is applied. Your laptop won't fry if you connect it to a PoE port, and your average child is also fairly unlikely to successfully finish a POE power negotiation. – MSalters Nov 07 '16 at 13:17
    @MSalters: Certain vendors do use 24V nonstandard "passive PoE", which requires no negotiation – but based on these posts I'm going to guess that's fairly safe? – user1686 Nov 07 '16 at 14:35
  • @grawity: Likely, but it's hard to pin down exactly what "non-standard POE" is doing. The name tells you what it isn't doing. – MSalters Nov 07 '16 at 14:41
    Hmm... Remember that 9V block on your tongue? Did you try 12V? It's quite a bite. That times four... ouch. It may not be absolutely lethal, but I imagine it could cause serious injury, maybe death through asphyxiation from spasms of your trachea. 48V in the mouth is probably just not safe. – JimmyB Nov 07 '16 at 16:58
    The kind of argument as presented in the answer is somewhere between useless and harmful, in my opinion. Yes, it is true that most times nothing will happen. Yes, it is true that directly touching 240V can have no effect whatsoever. But this is beside the point. The question with electricity (and gas, and water under pressure, and CO producing reactions, and ...) is not whether everything can go well, but whether anything can go wrong. At the end of the day, if your child is dead, disfigured or braindamaged, you do not care that there was only an outrageous 1% chance of that happening. – AnoE Nov 07 '16 at 17:01
    Right. I should probably have mentioned that a child could use the PoE cable as improvised rope to hang itself or that even an adult could trip over the cable and fall down the next stairway. As for the worst case regarding electric current (for which you must first plug the PSE, then a PD, then unplug the PD, and then put the cable in your mouth before the PSE detects the disconnect, all with a finger on the ground clamp), my opinion as "harmless" remains. Feel free to downvote the answer if you disagree. – Damon Nov 08 '16 at 09:02
  • Your comment re "around 45k" is too precise, and irrelevant if and until the current does get through the surface barrier. ie it could be 1 megohm and be hardly different, but if skin puncture occurs things "may change". 12V has killed in VERY exceptional cases. I would not trust my life to 48V, especially across my chest. I have read the "expert analysis" on which the latest ELV requlations are based and would still be wary. | 48V on a high humidity day causes annoying "bites" across the skin of your hand when working on a telecom 50V wiring frame. (Holiday job decades ago). – Russell McMahon Nov 08 '16 at 18:31
  • "While children are overall smaller and thus should have slightly lower impedance .." - Children have thinner skin than adults, so size matters a lot in this case. – inf3rno Feb 15 '18 at 17:08
  • As others already pointed out 48V in general should not too easily be deemed as save. All is extremely dependent on circumstances and the point where you get bitten, and you can easily die if an electrolysis path crosses your heart (wanna try it?). Proper POE implementation are a different story but non-standard devices can be dangerous of course. – datenheim Dec 24 '22 at 11:20
Different areas of the world differ slightly, but the 'safe' level for low voltage tends to be pitched at the 40 to 60v range, below which it is deemed that the likelyhood of electrocution is negligible. 'High voltage' cars use 42v, 3 '12v' batteries in series.
120v is sufficiently hazardous that plenty of people die of 120v mains shocks. Apparently more Americans die of 120v than Europeans die of 240v, perhaps due to a sense of complacency over the lower voltage (somebody check on snopes and debunk if necessary!)
Neil_UK
  • 166,079
  • 185
  • 408
    The UK has extremely robust and well designed mains connectors, the 13A BS1363 fused plug and socket arrangement which domestic users mostly encounter is a design masterpiece. – Ian Bland Nov 06 '16 at 10:43
    @IanBland I'm glad you got that off your chest Ian, it was obviously a feeling in urgent need of expression, whether relevant to the Q/A or not. – Neil_UK Nov 06 '16 at 12:19
  • @Neil_UK, I think he just meant that the UK's connectors are "complacency proof". Although that does make the assumption that the plug was wired by a competent person, which is not always the case, alas. –  Nov 06 '16 at 12:40
  • 17
    @IanBland: Most of Europe doesn't use the super-robust UK plugs, though. Still, having personally witnessed US power plugs hanging halfway out of the socket, with nearly a finger's width of exposed live metal, I can definitely say that even the crappiest Euro plug I've seen has been better than that. – Ilmari Karonen Nov 06 '16 at 13:08
    @Neil_UK I was just pointing out that this kind of safety is largely down to industrial design of things like connectors. 11kV is safe if nobody is able to accidentally touch it and when faults occur they keep the bang in. As Ilmari intimates below, a flimsy connector which easily exposes the live parts is where danger appears. And the 13A plug is simply a very good design for a consumer level connector. – Ian Bland Nov 06 '16 at 14:04
    The other point being that RJ45s aren't designed to produce any kind of safety isolation. The original question refers to children who tend to have a rather low impedance. I do know that when I was 7 years or so old, I could get quite a "tingle" off my 12VDC model railway tracks which was not dangerous (presumably) but I did find distressing. I wouldn't personally connect a child to 48V. – Ian Bland Nov 06 '16 at 14:08
    A domestic mains system, be it 240V or 120V will never, never use plug-to-plug cords (yes, I know that people have jury rigged such to unsafely connect generators, but they are certainly not endorsed to be used in ANY non-laboratory/industrial scenario) - networking hardware commonly does exactly that... – rackandboneman Nov 07 '16 at 09:32
    @IanBland: The RJ-45 end is entirely safe. If it's exposed, there's no 48V applied from the other end. POE requires negotiation before full power is made available. I'm not sure whether you get 5V or 12V to handle the negotiation. – MSalters Nov 07 '16 at 13:21
    If the UK has great mains connectors, the rest of us Europeans should be even safer with our Schuko. – JimmyB Nov 07 '16 at 17:04
    @JimmyB I'm not a fan of the Schuko's earthing arrangements myself ;) – Ian Bland Nov 07 '16 at 20:45
  • I think you should back this answer with a reference. In the current form it is just an opinion, and I think it is a wrong one beucase correlation does not instantly means causation. Not to mention that you have only anecdotal evidence for the correlation. (I was talking about the 120V vs 240V part) – inf3rno Feb 15 '18 at 17:51
  • Being a physicist, having lived decades in both continents and having performed every aspect of domestic wiring, up-to-code, I'll put in my observation: It is very easy to touch the hot connector while plugging in a U.S. appliance. It often remains slightly exposed. The recessed European receptacles do not expose the contacts until disconnected from the main. The government fails as always: overregulating things that they shouldn't and failing to regulate that which could save your life. – Jordan Feb 27 '22 at 14:47
First off, some people seem to have fixated on POTS which is nothing like PoE. Props to all the telecom engineers who've had ringing current up the arm on a sweaty day running jumpers.
Further to the good answers above about the safety of 48vDC in itself, PoE is a negotiated protocol - the connected devices start from the fail-safe assumption that the other device is NOT PoE compatible and therefore would not enjoy having power shoved up its interface. Only when two PoE-compatible devices are connected does one see the special signalling that tells it it might want to offer PoE - from there, the two devices will negotiate on what one needs / what the other can deliver and will effectively "work up" towards the required power level. It's also worth noting the power they arrive at could be much lower than the full amount supported - very few devices are that power hungry.
A disconnected or dangling cable (one end plugged into a PoE port) will NOT have an appreciable voltage on it - in fact no more than a standard ethernet cable.
In short, unless your kid manages to chew through a connected & working PoE cable AND bridge the conductors but miraculously WITHOUT causing the devices to spot the fault / lose connection, it's unlikely you could even get to the delicious volts inside before it's all shut down.
WARNING: This assumes real standards-compliant PoE devices rather than the many proprietary ways companies find of getting power up an ethernet cable, which often consists of a wall-wart wired to the spare wires in an ethernet adapter. In that case, you are at the mercy of the power supply - it could be some small anemic low-voltage wall-wart that's no issue at all or it could be a relatively high-current 48v or higher unit which MIGHT be a bit more risky, but frankly unless you've bought some ridiculous non-standards compliant not-really-PoE ethernet-connected floodlight or something you're at low risk.
One example I've seen of relatively high-power PoE-ish devices are high-end CCTV cameras with high-power LED's and full PTZ movement, they can draw 100-200W, but in the home it'd be very unlikely you'd ever find something like that.
Well, you might in my home, but, y'know...
Most other not-quite-PoE devices I've seen are just squirting 12-24v up the spare pairs from a <50w power brick or wall wart.
John U
  • 7,139
  • 22
  • 37
  • The negotiation part is interesting, I didn't know about it. Could you please elaborate on how the negotiation happens? Thank you. – Petr Nov 09 '16 at 06:15
  • I can't elaborate as I haven't read the standards document (and, as ever, there's other competing standards in the market) but the principle is basically the same all round - as you're adding power to a connector that, by default, is only used for data you can't just assume the other end will be OK with it, you have to detect & negotiate. – John U Nov 09 '16 at 14:12
In Europe, the maximum voltage for child toys is 24 V DC only. If applied directly over the heart at chest and back, even smaller voltages may be dangerous.
Uwe
  • 1,602
IEC 62368-1:2014 defines "safe" as 60VDC or 2mA DC, whichever is less. For AC the limits are 30VAC and 0.5mA. These are considered safe for an ordinary person but you still cannot leave exposed connectors/wires lying around as there's the whole chapter of "electrical fires" to consider.
There are higher limits for an "instructed person" e.g. service techies. These are 120VDC and 50VAC, with a special exception given for 90VAC telephone network ringing. These are defined as being noticeable or even unpleasant but usually would not produce harmful electrical physiological effects.. Current limits are 25mA DC and 5mA AC.
Anything above that is considered dangerous with "normal" frequencies, SMPS circuits might exceed the 100kHz AC limit but that's beyond the scope here.
Barleyman
  • 3,646
  • 14
  • 27
A couple of other answers mention 48V DC being a "safe" voltage, however I would argue that the environmental conditions (grounding, skin conductance etc) are far more important factors than just voltage.
The following is anecdotal admittedly, but I have experienced a very nasty DC shock working on a 48V DC gyro on a ship after coming inside with wet salty hands.
See also the following stackexchange answer that claims even 24V can be dangerous under certain conditions. How much voltage is "dangerous"?
Ralph
  • 143
What is more important than voltage in electrical safety is current. The amount of current required to start or stop the heart is 60 mA across the chest. Under the right circumstances even 12 volts can be lethal. In a marine environment- i.e capsized boat in salt water any person in the current path could be killed. 48 Volts could give you a healthy jolt if your skin is moist with sweat. Under normal circumstances with dry skin 48 Volts would probably wake you up but not kill you. When the the electrical current is strong enough to burn away the layer of skin and fat and comes in contact with the tissue directly below this layer it is extremely conductive then even relative low voltages can be lethal.
AC is far more deadly than DC- One of the reasons it is the preferred for performing an execution in the old days.
Old_Fossil
  • 383
    "The amount of current required to start or stop the heart is 60 mA across the chest." No, at 60 mA stopping the heart is almost guaranteed. Lower values, like 20 mA can still be enough to irregulate your heartbeat enough to crash it. – Mast Nov 07 '16 at 11:15
    The reason for the preferration of AC for executions in the old days was the bad campaign of Edison against the AC current of Tesla and Westinghouse. Edison wanted to change the public opinion, AC current should appear to be more dangerous than Edisons DC current. Generation of high voltages was much easier with AC than DC in those days. – Uwe Nov 07 '16 at 12:45
  • @uwe: That was one of the reasons as well. However that doesn't change the fact the AC is far more lethal because of frying of neural synapses which are designed to conduct in one direction at a time as opposed to 60 times a second both ways. – Old_Fossil Nov 07 '16 at 14:51
    Speaking as someone who's dealt a lot with electric shock risk, DC is always the scary one. AC tends to cause a spasm that throws you off the conductor, DC can clamp you onto it. It will lock the muscles rigid, whereas they still have some leeway to move with AC. And if there's enough current to fry anything, you're probably dead, frankly. A survivable shock just interrupts the functioning of the nervous system. It's the difference between a circuit needing a restart/boot, and the magic smoke escaping from components. Also, Uwe is right about Edison. It's a grisly tale. – Ian Bland Nov 07 '16 at 20:44
