I was wondering:
what is the function of the 2 resistors(R4 and R5) in series with the input pins of the given Instrumentation amplifier?
Thank you! enter image description here
Hilton Khadka
  • 831
  • 13
  • 29
Short answer : Safety current limit for CM input range input Vcb forward bias current from 0.22Ω* current pulse as the source during OFF commutation or unintended loose wire contact when running.
  • Also ground shift from poor wiring ESL. where Vemf=Ldi/dt for sense wiring L
  • Normally the shunt R 0.22Ω is designed for 50mV drop at max rated current to keep I^2R losses low. But as we know Motor DCR cause start currents >8x the Imax rated current, the negative voltage on the current shunt may exceed -100mV rating for CM input range on this INA.
  • If it exceeds -600mV then the input Vbe of the PNP base collector begins to conduct and will blow the front end. So a wise choice of R value is to limit the current with some experience.
  • Negative voltages occur from back EMF when the motor is shunted to stop, then it acts as a generator and V = L dI/dt depends on both conduction current and rate of change of current (negative) switching when motor is turned Off also resulting in a negative current spike.
Tony Stewart EE75
  • 54
  • 185
