A solar panel is a current source but has a Voc limit where Vmp =85%Voc at full current and drops to 70~75%Voc at <10% rated short circuit current with overcast or 10% solar power input.
This applies at 25'C to many, but not all PV's.
I like to model PV's like diodes so that the voltage will rise with current to match the Vmp for increasing solar power as close as possible without tracking.
So your Active load should be 14V regulated sink+ 0.75 Ohm
How you dissipate 85W and regulate this load is up to you and there are many many ways to implement this after you have a datasheet with these parameters to verify ( if possible please)
Series drop resistor or two 50W 14V headlamps drops to 5A LDO (quasi PNP emitter out) to a 100mV current shunt at 5V to ground. 20 milliohm calibrated wire.
Adjust the Regulator to ~12.7V such that PV is 17V at max solar power.
Then LDO input is ~13.8V and R12 such that I shunt reads 4.4Amp*20mOhm = 88mV
Addendum
Maximum Power Transfer Function Theorem wiki
the resistance of the load must equal the resistance of the source as viewed from its output terminals. Moritz von Jacobi published the maximum power (transfer) theorem around 1840; it is also referred to as "Jacobi's law".
Below is the OP's BP 275U I-V Curves 75W 19V Solar Panel conjugated by rotating and flipping the graph.
- The same is true for reactive source and load impedances in RF antenna power optimization with conjugate matching
- perhaps same is true for battery charging with pulses where a capacitive low ESR battery should be charged with a conjugate matched source ( inductive).
