I want to model a single one master and two I2C Slaves on a bus. I want to determine how long I can make the I2C Trace to the last/second slave.
How to model the length of the I2C Bus in LTSpice? Should I be using a transmission line model?
user1406716
  • 841
  • 14
  • 28
    This is an unusual goal for a simulation. For a more global picture of the problem, what bus length do you hope to achieve? – dim Oct 12 '16 at 20:56
    Probably this post may be of help, http://electronics.stackexchange.com/questions/106265/maximum-i2c-bus-length – Ale..chenski Oct 13 '16 at 00:35
The length of the I2C bus manifests itself as capacitance, and you can model it as a lumped capacitor. The I2C bus (assuming typical short distances which it's intended for) is way to slow to be concerned with transmission line model.
Nick Alexeev
  • 38,181
  • 17
  • 100
  • 237
Unless you've got a ground plane with a capacitance which the trace works against, The length of the trace manifests itself as inductance, so if you have a problem with delay you should tune it.
EM Fields
  • 17,527
  • 19
  • 23
If you need to design your own I2C receivers and want to see now reflections might affect your sampling point, use of transmission line model is always useful and educational. For a fast mode (up to 3.4MHz) the reflections might chew up a significant portion of bit time.
Ale..chenski
  • 40,470
  • 39
  • 109
