I have a speaker adapter, with an output rating of AC 11.5V ~ 1600mA, which I am looking to replace and the only replacement I can find has a rated output of 12V ~ 2000mA.
I've read somewhere that a higher current is okay since the speakers will only draw what it needs, but I'm wary if the 0.5 difference in voltage will overload/damage it.
budji
  • 113
  • Thank you, that was a very informative read. The only thing missing is how much of a deviation in output voltage can be considered "safe" to use. – budji Jun 09 '16 at 11:51
  • It's hard to say how much more voltage is safe. In this case, going from 11.5 to 12 is probably OK. – Olin Lathrop Jun 09 '16 at 11:54
  • An AC power adapter is just a transformer, if your mains voltage is 220 V you might get 11.5 V but when it is 230 V you would get 12 V ! Your mains supply voltage is not that accurate so devices using a AC transformer must be able to withstand a higher voltage. I think a device rated for 11.5 V AC must be able to handle 12 V AC without any problem. – Bimpelrekkie Jun 09 '16 at 12:03
For this kind of thing where it's just an unregulated AC transformer it's probably fine; I suspect if you had measured the original transformer it wouldn't be exactly 11.5V.
Although if it's a linear power supply it might put out slightly more heat than it used to, which may not be safe.
pjc50
  • 46,725
  • 65
  • 126
