When I update the PCB layout from the schematic, it will place some room on the PCB editor for each sheet. How to remove this all in once ? Is there are a way to select them all in once and to delete them?
Krunal Desai
  • 6,306
  • 22
  • 32
chris
  • 1,583
  • 25
  • 44
You should just change your ECO generation options to not automatically create them if you're not using them:
Otherwise to remove the rooms, yes, you can just select them in the PCB Editor and delete them.
Krunal Desai
  • 6,306
  • 22
  • 32
  • thank you. I never understood why they create a room for this. – chris Jun 06 '16 at 19:46
  • I think the MO they assume for it is if you have components on a given sheet, they'll belong together in layout, or in multi-channel devices, it's one of the things that supports being able to easily duplicate your layout across channels. – Krunal Desai Jun 06 '16 at 19:53
