how do I hook a PNP sensor to a raspberry pi 3? I know I need an A/D converter, and I've already got a MCP3008. But apart from that, what else do I need? The sensor output switches 24v or 0v, I also know I have to bring it down to 3,3V. Thanks a lot guys!
1What sensor? Why do you need an ADC? – Tom Carpenter May 07 '16 at 16:07
rpi doesn't work with analog signals – Roberto Mack May 09 '16 at 02:46
that assumes it is an analogue sensor. You haven't specified what sensor it is, so how do we know. – Tom Carpenter May 09 '16 at 11:34
The sensor output switches 24 V or 0 V.
That means it's a digital sensor and should be connected to a digital input. You use analog inputs for varying signals which are "analogous" to the physical property you are measuring - e.g., temperature, pressure, etc.
So we need to divide the voltage by 3.3 / 24 = 7.3. 68k and 10k as shown in Figure 1 should do the job.
The resistor values are high to keep currents low. If you have a two-wire sensor it may need a certain current in the 'off' condition to power the electronics. In that case we may need to scale the resistors down by a factor of 10 or so. Let us know and post a link to the sensor datasheet.
- 175,532
- 13
- 190
- 404
http://www.leuze.com/en/deutschland/produkte/schaltende_sensoren/optische_sensoren/lichtschranken_lichttaster_zylindrisch/baureihe_318_kunststoff/lichttaster/rt_hrt_3/selector.php?supplier_aid=50122564&grp_id=1332237561758&lang=eng#{"tab":"2"} – Roberto Mack May 09 '16 at 02:50
just click on downloads and find the datasheet in your preferred language...
thanks a lot dude! btw I'll still need the a/d for the analog sensors
– Roberto Mack May 09 '16 at 02:51 -
OK. There's no mention of analog in your question. Industrial analog sensors will be 0 - 10 V or 4 - 20 mA. – Transistor May 09 '16 at 07:27
You can use a voltage divider as so:
It will work with R1 and R4 as a single 30K resistor, with C1 missing, and with R3 shorted, D1, D2 missing, but the suggested parts add more immunity to
- 397,265
- 22
- 337
- 893
D1 is not necessarily mandatory if the 24V is regulated and the wires reasonable length, but it's not a bad idea. – Spehro Pefhany May 09 '16 at 04:56
