Thermistor / Voltmeter
Assume that I had a circuit as such above. I was wondering, if I increased the temperature of the surroundings, what would a graph of the temperature/PD graph look like?
I know that Resistance decreases with temperature, as more electrons 'escape' from their atoms, so more charge carriers are available, but would the graph show a general decrease in PD as temperature increases?
Thanks.
wythagoras
  • 115
vik1245
  • 123
    Would [electronics.se] be a better home for this question? – Qmechanic Apr 30 '16 at 21:40
    The temperature curves of thermistors are technology dependent and can be found in the data sheets. Once you have that, you simply apply a resistor divider formula. –  Apr 30 '16 at 21:42
There are a few formulas to model the behavior of an NTC. The most common (and simlest) one is the b-Formula:
$$R(T)=R_0\cdot \exp\left(b\cdot \left(\frac{1}{T}-\frac{1}{T_0})\right)\right)$$
T is given in Kelvin, and b is a parameter of the NTC type, typically in the order of 3000-5000. \$R_0\$ is the resistance at \$T_0=298.15K(=25°C)\$.
Putting this into the formula of a voltage divider, one gets this plots:
For the first curves, the normal resistor \$R_N\$has a value equal to \$R_0\$, for the two, it has a value of \$200R_0\$ or \$(1/200)R_0\$
So there are three conclusions:
  • The higher the b-value, the higher the sensivity (slope), but the smaller the temperature range.
  • The highest sensitivity is at the temperature T where \$R(T)=R_N\$, and it decreases with temperature difference from T.
  • Choosing an other value for \$R_N\$ allows to shift the usable range, but the sensitivy / range will change, too.
sweber
  • 8,640
  • 16
  • 36
