I have lm2576 switching regulator circuit with output constant 5v/3A. Can I use it with a 12V battery and connect it to power my Arduino?
Bence Kaulics
  • 6,413
  • 34
  • 60
rezhart
If you are using something like the Arduino Uno that has a power jack, you can just directly connect the 12V to the power jack as the Arduino has an internal voltage regulator (although not a buck converter I believe).
Or you could use the buck converter IC (Lm2576) you mentioned and follow figure 1 exactly from the datasheet and place the output through USB or the 5V pin instead.
Bence Kaulics
  • 6,413
  • 34
  • 60
Bradman175
  • 1,191
  • 22
