What exactly is the bottleneck that might prevent a bluetooth device from being able to pair to more than one peripheral device at a time? Is it the connection, antenna, protocol, etc?
I'm planning to use a Gumstix module that connects to a bluetooth antenna with a U.FL connection and I can't find any information on whether it supports multiple device pairing. I don't know enough about how to bluetooth actually works to try to determine this on my own based on the specifications. Any help is greatly appreciated, thanks.
edit: I originally said multiple pairing, but I'm actually requiring multiple connections I believe to get multiple RSSI signals at the same time. RSSI requires full connection and not just paired right?
For background information I need to use multiple pairing in order to do some type of positioning calculations with bluetooth beacons using RSSI parameters. This is the board I have to use: https://store.gumstix.com/verdex-pro-xm4-bt-com.html
