-1
Title says it all, Ive got many an adaptor lying around, do I need another 6v .8a at 240v?
I should note ive had it plugged into the mains with a standard international adaptor for over three years now no problem. looking to lose the adaptor.
JPB
  • 101
  • It seems as though you're using "adapter" in two different senses here, making your question extremely difficult to follow. Could you be more explicit about what you're trying to do? – Dave Tweed Mar 12 '16 at 14:40
  • sorry, wallwart is 120v, using international adaptor to change plug configuration from us to aus. – JPB Mar 12 '16 at 16:04
    A picture is worth a thousand words. Show us what you have and which part of it you want to "lose". – Dave Tweed Mar 12 '16 at 16:15
  • Please read the answer linked in @PeterJ's comment. It is worth your time. – user57037 Mar 13 '16 at 05:44
You need a 240V AC to 6V DC 800mA adapter. On the output side you need the 6V and 800mA regardless of what is on the input side. A lot of AC adapters can handle both 120V and 240V. Check the input specification printed on the adapter. If it can accept 240V then all you need is a physical plug converter.
Willis Blackburn
  • 1,247
  • 14
  • 24
  • it doesnt say 240v just 120. So voltage makes no difference? – JPB Mar 12 '16 at 16:05
    That isn't what he said. Voltage most definitely does make a difference. Some wallwarts can work on any voltage from 120V to 240V, while others are 120V only or 240V only. If your "international adapter" is just a physical adapter for the plug, then your wallwart is already operating at 240V. If the adapter is a transformer of some sort, then you need to find a new wallwart that accepts 240V AC and produces 6V DC at a minimum of 800 mA. What exactly are you trying to "lose"? – Dave Tweed Mar 12 '16 at 16:11
