I am trying to find the most power efficient method for heating a metal tube in order to heat up the airflow within it. I came across the Minco mica heater but when I talked to another engineer they said it would be just as effective to simply wrap the cylinder in heater wire and then put ceramic tape over the top. Is there a good way to determine which route is better without buying and trying?
I am trying to maximize airflow through the tube, hence heating the tube itself, and not heating the air directly inside.
I am not stuck on a cylinder, necessarily, but from a mechanical standpoint, it seemed like the most effective shape to take advantage of the heat, but that was possibly a terrible assumption.
