In Control systems, when it comes to governer control, I came across with a term Stiff Load.
Can someone please explain what it means?
A "stiff load" in a mechanical system is one which does not undergo substantial deformation or interaction with forces applied to it.
ie the reaction to applied forces is from other flexible or variable parts of the system rather than to the load proper.
Wikipedia here says:
Note that "stiffness' relates not only to the axis along the axis where a "force" is applied but also the degree of coupling to other axes.
In an electrical system a stiff system would be one where eg the load on a power supply did not vary as voltage varied - not a usual situation.
Stiff means the value of interest doesn't change much as varying pressure is applied that should change it. For example, concrete is stiff because it deflects little with applied force. Rubber is much less stiff.
In electronics stiff is usually used to describe a voltage source and means low impedance in that case. The voltage changes little with different currents. It is less common, but you could also say a current source is "stiff". In that case it means very high impedance. The current changes little with different voltages. In either case the value of interest doesn't change much as a function of applied conditions.
