12
I have an old 12V cooler master fan that I am converting into a fume extractor for soldering and am connecting it to a standard 12v computer power supply. I am trying to wire it and am confused about one thing.
On the fan's label it has a coding for the different wire colors (red, black, and white) and it says:
red +
black -
white FG
I have looked up FG on google all over the place but can't seem to find anything that says what it stands for. I was thinking that it might be "Ground" but then what would the black negative wire be? Maybe I just have a fundamental misunderstanding (pretty new to all of this electronics stuff)
I did connect the black wire on the fan to a black wire on my power supply and the red wire on the fan to a yellow wire on the power supply (white wire connected to nothing) and it turned on and seemed to be working fine but I want to make sure that this is actually a correct wiring and isn't going to cause any problems in the future.
celeriko
  • 235
FG stands for Frequency Generator (or Feedback Generator), it has an output with a frequency proportional to the fans speed. It is used by the CPU to determine the fans speed.
Some (older) fans have an extra winding internally and the FG signal is a sinusoid with both amplitude and frequency proportional to fan speed.
Modern fans almost exclusively use a Hall-Effect sensor and the signal is an open-collector square-wave signal where the frequency is proportional to fan speed. Peak voltage is determined by the magnitude of the power supply that feeds the pull-up resistor.
Dwayne Reid
  • 23,792
  • 38
  • 70
Steve G
  • 5,305
  • 14
  • 24
Be careful. I seen AC-DC power suppliers labeling "FG" for the frame ground. That means, attaching to the metal of the device.
-1
I'm pretty sure that FG here stands for "floating ground", which is an isolated ground for the analog circuits inside the power supply.
BlackPenguin
  • 171
