I need information on the major difference between an WHOLE CURRENT energy meter and a KWH energy meter, if there is.Any link or resource information would be of great help.
Thanks
"Whole Current Meter" is an industry jargon term for a (probably) single phase meter used to measure AC mains current in which the whole current to be measured flows directly through the meter - as opposed to eg current transformer type measuring systems where the current is converted to an indirect variable which is measured by a meter which is not directly measuring the actual current.
This reference "Automated Meter Reading Key Information for Members" says on page 6
This document "Validating non-utility meters for NABERS rating" notes some important practical consequences and areas of application. Viz -
Electricity meters ... are either ‘whole current’ (direct connect), where all the electricity flows through the meter, or CT meters, where the electricity flows through a Current Transformer which reduces the electricity to flow through the meter by a defined ratio.
A whole current meter is typically used for loads up to 100 amps and CT meters for larger loads. An exception to this is where small panel mounted electronic meters are installed that use CTs regardless of the current flow
All non-utility electricity meters with CTs must be validated (and corrected if necessary) by a licensed electrician or electrical engineer to ensure that the CT ratio (meter multiplication factor) and wiring is correctly configured.
But
Note: A whole current meter measure current (Amps) and not energy (KwH) but a kWh meter may conceivably use either whole current or current transformer measurement methods.
