20
In this Linear Tech App Note 13, page 28, Jim describes:
A final form of probe is the human finger. Probing the circuit with a finger can accentuate desired or undesired effects, giving clues that may be useful. The finger can be used to introduce stray capacitance to a suspected circuit node while observing results on the CRT. Two fingers, lightly moistened, can be used to provide an experimental resistance path. Some high speed engineers are particularly adept at these techniques and can estimate the capacitive and resistive effects created with surprising accuracy.
Was he joking? If not, how do the such techniques work in practice to provide accurate estimation? Could anyone describe an actual scenario that those engineers applied such techniques?
The application note, and my question is in regards to low voltage, high speed signals, not mains or high voltage.
Peter Mortensen
  • 1,679
  • 17
  • 23
Eagle Shou
  • 399
  • Use ONLY when you know that the voltages present are NOT hazardous. – JRE Oct 15 '15 at 06:56
  • This means that circuit must be mains isolated and that it must use low voltages (below 50 Volts but personally I would not even touch circuits above 20 V). – Bimpelrekkie Oct 15 '15 at 07:03
    That title... creeps me out. – Passerby Oct 15 '15 at 07:06
    I do sometimes use my finger in audio circuits to inject a signal (50 Hz from mains with a lot of distortion so easy to hear). This will work if the point in the circuit is high-impedance and sensitive enough. Suprising accuracy ? I doubt it, I guess the engineers were just lucky. – Bimpelrekkie Oct 15 '15 at 07:06
  • I am sorry that my question might be confusing. I tagged it with "high-speed". I originally intended to discuss high speed microelectronics mixed-signal oscilloscope measurement techniques (normally 5 V or below) . (Thanks @passerby for editing!) – Eagle Shou Oct 15 '15 at 07:10
    The most dangerous part of testing with touch is creating a path for High Voltage/Current through the heart. Passing the current between two fingers is much less dangerous. AN old electronics shop class teacher used to do it for a mains voltage shock toy he built. Myself, much less adventurous, test 9v batteries with my tongue. I can tell how much life is left by how weird my tongue feels afterwards. – Passerby Oct 15 '15 at 07:13
  • Touching different parts of the circuit sometimes helps locate a problem during debugging. Usually, for me, it happens by accident when I am trying to press a button or connect or disconnect a connector. Usually it reveals manufacturing flaws like cold solder joint. But it can also flush out open digital inputs or something like that. – user57037 Oct 15 '15 at 07:15
    Using google I have discovered that he mentioned this in several other app notes. I don't think it is a joke. But I think Jim Williams belonged to the group of pioneers of analog electronics, and they prided themselves on their eccentricities. You can read about Widlar and Bob Pease, etc. People who designed the circuits used in textbooks and were responsible for the creation of all the IC companies we know and love. – user57037 Oct 15 '15 at 07:32
    Also good for causing opamps to oscillate in my experience, by touching their output. It turns out the human body capacitance is "just right" for quite a few opams to go crazy. Actually, I've recently seen some experiments confirming the human body capacitance values I kinda suspected: https://youtu.be/vNpGoNP1tGQ?t=174 – the gods from engineering Oct 15 '15 at 07:52
    Some hard core engineers ate embedding neodymium magnets in their finger tip to sense ac :) – BenG Oct 15 '15 at 10:32
    @Passerby Perhaps. But obviously it would be safe as long as you attach an insulated handle to the human finger and don't touch it directly. – Random832 Oct 15 '15 at 18:15
A finger is a very useful item of test equipment. The main problem when fault finding is knowing which bits of the circuit are susceptible, and which bits are OK. As you stare, dumbfounded, at a recalcitrant bit of board, it's good to be able to get any handle on what is going on, just a hint of where to start looking more closely. At one place I worked, its use was known as 'the laying on of hands'. A finger has the following uses and advantages.
  1. It is always available
  2. It can be used to inject ambient signals into a node, increasing the output of hum of RF breakthrough. Generally useful with high impedance low frequency circuits. Use capacitive (dry skin) or resistive (wet skin) coupling.
  3. It can be used to ground a node.
  4. At low frequencies it can add capacitance to a node, changing time constants, filter tuning etc.
  5. At microwave frequencies, it can absorb and redistribute RF radiation, damp resonances, reduce signal levels, absorb the higher harmonics on an open signal line.
  6. It's not generally recognised that high speed busses to memories and FPGAs are now running so fast that a finger on the lines will change rise-times, introduce crosstalk between clock and data, or reduce clock ringing, any of which can affect data integrity. I have dabbed a data bus while looking at the resultant TV picture, and could tell whether I had address setup or data crosstalk problems.
  7. It can take the temperature of components, from 'that's OK' through 'it's running a bit hot' to '$$$ it's that one!'
  8. It can cool selected hot components, improving the heatsinking, to see if temperature changes matter.
  9. The speed. While watching an oscilloscope trace, listening to a demodulated signal, or watching a BER number, you can stroke your finger across a whole board in seconds. Any place it changes, that's a good place to think about whether you expected it to change there.
As a seasoned engineer, there have been many times in my career when several of us have sat round a mis-performing board, and the joke round the table was that if we could 'buy an engineer's finger, and glue it just there', we'd be good to ship.
And the question of accuracy. You don't need 3 digit accuracy, you need to know whether none, or a few pFs, makes a difference here. Once you know where to play with, you switch back to soldering chip components or trimmers.
And yes, all this usefulness comes at a price, you must not use it on circuits above 40v.
Neil_UK
  • 166,079
  • 185
  • 408
  • 13
    f) It can take the temperature of components, from 'that's OK' through 'it's running a bit hot' to '$$$ it's that one!' - which can include branding the manufacturer's logo into your finger tip. – JRE Oct 15 '15 at 08:43
    The big mystery of RF design: "How do I build the electrical equivalent of a finger, using electrical components?" ;-) An analysis using solid theory is one thing, troubleshooting is another. Engineering is using both. – zebonaut Oct 15 '15 at 08:53
    "3 digit accuracy" - I see what you did there. – Gusdor Oct 15 '15 at 14:19
    +1. You could add another use of "wet finger test" - it allows to detect signals that are insufficiently biased (floating) - if a small, 200-500k leakage through a wet finger causes some unconnected or configuration pins to disrupt device's functionality, one can surely expect problems in mass manufacturing due to possible flux contamination (no-clean fluxes are notoriously bad, and can develop conductive "bridges" down to 5-10kOhms of resistance, dependent on ambient humidity). – Ale..chenski Jan 09 '17 at 21:22
  • You can also "pull" a bias voltage up or down with your finger in a high-Z circuit by touching a finger to both it and a ground or supply voltage – endolith Mar 24 '17 at 19:31
